Chip-84
A Chip-8 emulator/interpreter for the TI-84 Plus CE. Most if not all games should work as all opcodes are implemented, including Super Chip-8 instructions. The zip file contains a ROM converter, the emulator, and a readme explaining how to set everything up. (v2.3.0)
Screenshot #6428 Screenshot #6429 Screenshot #6430 Screenshot #6431 Screenshot #6432 Screenshot #6433 Screenshot #6434 Screenshot #6435
Chip-84 Converter.exe 6.0 KB
CHIP84.8xp 9.9 KB
readme.txt 278 bytes
7.9 KB
ckosmic
5 years, 5 months ago
9/10 (2 votes)
Have you ever heard of CHIP-8 before? I hadn't until 2 days ago. Didn't matter, I still loved this emulator the moment I tried it out! **PROS: *Very easy and straight forward to use the emulator and converter. *It has a few useful setting to adjust things such as custom key mapping (Amazing!) and cycles per frame. You can even pause the emulated game whenever you'd like. *The games are normally under 1kb which is far less than nearly every ASM/C program and less than the size of a decent BASIC game! This means you can store as many of these games as you'd like! (Note, most of the games are very simple) **CONS: *I don't really have any cons about the emulator itself, the emulator is stable and just does its job well. Only some of the games are too simple and slow to be much fun. **CONCLUSION: This is a great emulator which will provide many hours of enjoyment when you're bored or just want to play a simple space-friendly game. [10/10]
  1. Chip-84 (published 5 years, 5 months ago; 2018-06-27 07:25 UTC)
