This is special characters! Special characters is a really simply program which saves a bunch of special characters you can't get through normal means to any string of your choice to use for your programs!
DOES NOT REQUIRE DOORS
README.txt | 509 bytes |
SPECCHAR.8xp | 718 bytes |
- 1017 bytes
- http://ceme.tech/DL1723
- exoRift
- 5 years, 10 months ago
- 5/10 (3 votes)
This is an OK program that gives you a few characters to store into a string. **PROS: *very small *Easy to use (only requires your input once) **CONS: *This is my only con, but it's a big one. This only has the special characters "#$%;@>" for you to use. That's not very many, I would've expected many more characters given the name. Hopefully more will come with an update. **CONCLUSION I think this is a decent program, but it just doesn't have nearly as much content as I'd hope. [6/10]
- Special Characters (published 5 years, 10 months ago; 2018-02-05 18:49 UTC)
