Is it Divisible?
  4. TI-84 Plus CE BASIC Math Programs
My very first program. View all the necessary details in the included README.txt.
ZIP includes file, README, and several screenshots.
Screenshot #6177
iid/iid.8xp 301 bytes
iid/iid_step1.png 1.7 KB
iid/iid_step2.png 2.3 KB
iid/iid_step3.png 2.2 KB
iid/iid_step4.png 2.0 KB
iid/iid_step5.png 2.2 KB
iid/iid_step6.png 2.5 KB
iid/README.txt 2.2 KB
14.3 KB
VØRT3X
6 years, 6 months ago
1.5/10 (2 votes)
Here's what this program does: you enter a dividend, you enter a divisor, and it tells you if it's perfectly dividable or not.
**PROS:
*it works (most of the time)
*easy to use
**CONS:
*Poorly coded, looking though the code, I see there are many memory leaks
*there's no crash prevention so entering a divisor of 0 crashes the program
*when you first launch the program, it asks you if you want to run the program again. That would be better suited *after* I run the program.
*When you select 'no' (don't run the program again) You will encounter a Syntax error.
*The ReadMe.txt calls you a "scoundrel"
**CONCLUSION: I honestly don't see why this program is necessary. It's basically the / button in the form of a program with no obvious benefits. Hopefully the author will fix some of the errors found in this program and will make it display more useful information. [2/10]
  1. Is it Divisible? (published 6 years, 6 months ago; 2017-05-20 00:37 UTC)
