Can anyone verify that the ColorLine asm routine works?
Are you having trouble with the routine? Having a look at the documentation it seems that it uses index registers so interrupts should be disabled.
Have you tested it as well?
I use IM2 so the index registers aren't problem. I'll study it after I finish my entry, I'm working around it right now. When I call it, it resets the calc. If I comment it out, everything else works.
Oddly enough, I can actually replicate this crash. I could swear tr1p1ea's routine worked well enough for me when I tested before release, so this is definitely something I need to check and repair. Thanks for discovering the issue!
Ahh so it is the hacked up routine i wrote :X. Ill see if i can find the code.
Do you have any example code for me to look at asmbandit?
I have an example; it's from your original test program that you sent me, and still has your name at the top: Do you have any example code for me to look at asmbandit?
; tr1p1ea - 09/09/2013 (dd/mm/yyyy):
; TI-84+CSE drawLine test
.nolist
.include "ti84pcse.inc"
.include "dcse8.inc"
.define userMemC $A60B
.list
.org userMemC-2
.db $EF,$69
Main:
di
push iy
ld de,10 ; x0
ld bc,10 ; y0
ld hl,310 ; x1
ld ix,230 ; y1
ld iy,$F800 ; colour - red
call colorLine
ld de,150 ; x0
ld bc,34 ; y0
ld hl,50 ; x1
ld ix,200 ; y1
ld iy,$0320 ; colour - dark green
call colorLine
ld de,280 ; x0
ld bc,150 ; y0
ld hl,150 ; x1
ld ix,24 ; y1
ld iy,$867D ; colour - sky blue
call colorLine
ld de,310 ; x0
ld bc,150 ; y0
ld hl,310 ; x1
ld ix,24 ; y1
ld iy,$FFE0 ; colour - yellow
call colorLine
ld de,280 ; x0
ld bc,10 ; y0
ld hl,30 ; x1
ld ix,10 ; y1
ld iy,$FB08 ; colour - tomato
call colorLine
pop iy
bcall(_getkey) ; getkey
ret
I wonder if it resets the calc or if it causes the LCD to go into panic mode.
Perhaps this is a large program that goes over the $C000 limit?
I found out what happened. I used the drawPixel from xLIBC, but at some point along the line that changed, and I never corrected my routine to use your original version instead of xLIBC's modified version. That's what I'll have to fix.
tr1p1ea wrote:
Dang, when do you foresee a fix getting published?
I should have another DCSE update coming sooner rather than later, because Merthsoft also found an issue with Celtic 2's ReplaceLine function and made some suggestions to improve two other functions. Do you have any xLIBC improvements/replacements you want to make? Register to Join the Conversation
