Using getch and Beep, with some other stuff, im trying to make a program that plays music based on your keypresses. however, the console is spammed with tons of keys, even when i dont press anything. here is my code:
#include <stdio.h>
#include <stdlib.h>
#include <Windows.h>
int FGetKey();
int Input;
int GetKey;
int Atmp;
int Btmp;
int Ctmp;
int main()
    while (GetKey != 56)
      FGetKey();
    printf("Key: %d %x %c", GetKey, GetKey, GetKey);
    Atmp = GetKey * 100;
    Beep(Atmp, 200);
    return 0;
int FGetKey()
    GetKey = 0;
    while (GetKey != 0)
        GetKey = getch();
i cant see why the while loop isnt holding getch(); even if getch should wait for user input. any help?
I think your problem was that you were using getch(which is deprecated, by the way, you should use _getch instead) inside of 2 loops, when it only needs 1. Here's the code that I got to compile under MS Visual C++ 2010 (x86):
#include "stdafx.h"
#include <stdio.h>
#include <conio.h>
#include <stdlib.h>
#define WIN32_LEAN_AND_MEAN
int GetKey;
int Atmp;
int main()
    while (GetKey != '~')
      GetKey = _getch();
      if (GetKey != 0)
      printf("Key: %d %x %c\n", GetKey, GetKey, GetKey);
      Beep(Atmp, 200);
    return 0;
I also changed the quitting key to tilde, because _getch returns a char, not a keycode.
