I've been trying to use the Unofficial OpenGL SDK, but when I attempt to use the image loading library, I keep getting errors. Here is my code:
1 #include <stdlib.h>
2 #include <stdio.h>
3 #include <memory>
4 #include <glload/gl_all.h>
5 #include <glload/gll.hpp>
6 #include <glimg/glimg.h>
7 #include <GL/glfw.h>
8
9 using namespace glimg;
10
11 int main()
12 {
13     int     width, height;
14     int     frame = 0;
15     bool    running = true;
16
17     glfwInit();
18
19     if( !glfwOpenWindow( 1600, 900, 0, 0, 0, 0, 0, 0, GLFW_FULLSCREEN ) )
20     {
21         glfwTerminate();
22         return 0;
23     }
24
25     glfwSetWindowTitle("GLFW Application");
26
27 //////////////////////////////////////////////////////////////////////////////////
28     if(glload::LoadFunctions() == glload::LS_LOAD_FAILED)
29     {
30         running = false;
31         return 0;
32     }
33
34     GLuint theTexture = 0;
35
36     try
37     {
38         std::auto_ptr<glimg::ImageSet> pImgSet(glimg::loaders::stb::LoadFromFile("TestImage.png"));
39         theTexture = glimg::CreateTexture(pImgSet.get(), 0);
40     }
41     catch(glimg::loaders::stb::StbLoaderException &e)
42     {
43         printf("Image file loading failed.");
44     }
45     catch(glimg::TextureGenerationException &e)
46     {
47         printf("Texture creation failed.");
48     }
49 /////////////////////////////////////////////////////////////////////////////////
50
51     while(running)
52     {
53         frame++;
54
55         glfwGetWindowSize( &width, &height );
56         height = height > 0 ? height : 1;
57
58         glViewport( 0, 0, width, height );
59
60         glClearColor( 0.0f, 0.0f, 0.0f, 0.0f );
61         glClear( GL_COLOR_BUFFER_BIT );
62
63         glMatrixMode(GL_PROJECTION);
64         glLoadIdentity();
65         glOrtho(0.0,width,height,0.0,-1.0,1.0);
66
67         glfwSwapBuffers();
68
69         // exit if ESC was pressed or window was closed
70         running = !glfwGetKey(GLFW_KEY_ESC) && glfwGetWindowParam( GLFW_OPENED);
71     }
72
73     glfwTerminate();
74
75     return 0;
76 }
Here are the errors that I cant seem to fix:
C:\Users\Colin\Documents\CompDev\C++\TextureTest\main.cpp||In function 'int main()':|
C:\Users\Colin\Documents\CompDev\C++\TextureTest\main.cpp|45|error: expected type-specifier|
C:\Users\Colin\Documents\CompDev\C++\TextureTest\main.cpp|45|error: expected unqualified-id before '&' token|
C:\Users\Colin\Documents\CompDev\C++\TextureTest\main.cpp|45|error: expected ')' before '&' token|
C:\Users\Colin\Documents\CompDev\C++\TextureTest\main.cpp|45|error: expected '{' before '&' token|
C:\Users\Colin\Documents\CompDev\C++\TextureTest\main.cpp|45|error: 'e' was not declared in this scope|
C:\Users\Colin\Documents\CompDev\C++\TextureTest\main.cpp|45|error: expected ';' before ')' token|
||=== Build finished: 6 errors, 0 warnings (0 minutes, 1 seconds) ===|
I've tried commenting out the offending catch(), but the program always crashes before it can get to the main loop, and never due to failed image file loading.
