- 8X+ testers needed...
- 20 Apr 2013 11:51:58 am
- Last edited by the_mad_joob on 21 May 2013 06:04:08 am; edited 4 times in total
Hey there =]
If you don't already know, a delay is needed between writing and reading to the keyboard (using port 1).
The problem is, that the needed time is not accurately known.
Since there seems to be many different opinions about the subject, i decided to code a program to test that up.
The main purpose is to be able to have a better knowledge of the hardware, allowing more optimised low level operations.
Also, maybe we'll have some surprises (ti likes to change hardware pieces).
COMPATIBILITY
TI-83 Plus
TI-83 Plus.fr
TI-83 Plus Silver Edition
TI-84 Plus
TI-84 Pocket.fr
TI-84 Plus Silver Edition
TI-84 Plus Pocket Silver Edition
TI-84 Plus C Silver Edition
All official OS are compatible, as long as you TURN OFF MATHPRINT.
INSTRUCTIONS
Simply execute from the homescreen and follow instructions.
Important : When pressing the 0 key, you must HOLD it until the end of the test.
DOWNLOAD
black & white models : http://www.omnimaga.org/index.php?action=dlattach;topic=16102.0;attach=15043
TI-84 Plus C Silver Edition : http://www.omnimaga.org/index.php?action=dlattach;topic=16102.0;attach=15044
RESULTS
The displayed value(s) are the needed delays (in cycles) for each CPU speed mode (order : 0,1,2,3).
A question mark specifies an unknown delay.
Please don't forget to specify the model and serial number end (at the back of your calc, in the form X-XXXXX).
THANKS IN ADVANCE FOR YOUR PARTICIPATION =]
COMPATIBILITY
TI-83 Plus
TI-83 Plus.fr
TI-84 Plus
TI-84 Pocket.fr
INSTRUCTIONS
DOWNLOAD
RESULTS
OWNER MODEL SERIAL DELAY-0 DELAY-1 DELAY-2 DELAY-3
the_mad_joob 83+ I-0299A 6
bhtooefr 83+ S-0504E 0
chickendude 83+ N-0305H 5
fortytwo 83+SE I-0501 4 23 30 37 overclocked
Darl181 84+ S-0305B 6 29 29 29
Streetwalker 84+ S-0107G 4 21 21 21
the_mad_joob 84+SE S-0404 6 29 29 29
DrDnar 84+SE S-0605D 4 19 19 19
fortytwo 84+SE P-0410O 4 17 17 17
willwac 84+SE P-0410O 4 20 20 20
chickendude 84+SE ? 4 18 18 18
DrDnar 84+CSE ? 22 72 72 72
