Well, I was looking for the documentation, as the official documentation for Symbolic (at http://www.detachedsolutions.com/symbolic/) doesn't contain the documentation for the command"pretty(". It tells you to go to www.softtheiss.de for more info. I guess that that link isn't on the internet anymore.
You should really lead with your specific issue in the first post. It'll help get the appropriate answer to you faster; I've seen users (here and elsewhere) get frustrated and give up because they aren't supplying the information needed to help them, so the first page of posts is an attempt to pry that information from them; which they're usually resistant over because it isn't directly progressing their issue forward.
Now, I have to commend you for sticking with us as we shape you up to be a better forum poster
Unfortunately, I think the only readily available pretty print documentation you'll find is for outside the calculator. Maybe some specific Google searches using operators, filters and quotes can help you find a mirror of the TI documentation but it's more effort than I can afford to put in right now.
