So when I use multiple pxl-test statements back to back like this:
Text(0,0,pxl-Test(Y*(~1)+82,X+136
Text(0,10,pxl-Test(Y*(~1)+82,X+136
Text(0,20,pxl-Test(Y*(~1)+82,X+136
Text(0,30,pxl-Test(Y*(~1)+82,X+136
Text(0,40,pxl-Test(Y*(~1)+82,X+136
Only the first one works, all the others fail and display just 1 all the time.
Any idea what could be causing this and how to circumvent it??
The X and Y variables are often silently used by the OS when drawing things, which I'd guess is your problem.
Using variables other than X and Y will probably fix it, though I played with similar concepts and wasn't able to identify exactly what's changing them (so I can't be sure that's actually what's going wrong for you).
My guess would be that the Text() command itself is changing the Y variable. Common conventions including using A and B, C and R (column/row), or X and Z instead of X and Y.
Sorry I didnt check in earlier, thanks for the reponse!
Thanks allot Kerm! I just started using a matrix to solve my problem, but from now on i'll use A,B for coordinates...
