- TIFC re-write
- 28 Feb 2013 06:23:03 pm
- Last edited by tifreak8x on 10 Mar 2013 03:04:27 pm; edited 1 time in total
So, I'm devoting a bit of time to making this program more amazing for the 73, 82, 83 and 83+, and to lay the ground work for the 84+CSE.
I'm currently working on the 83+ version, and the new temperature conversions are put in, as suggested by comicIdiot.
Basically, you enter your value, and then select the conversion type. Then, say for temps, you have
F>
C>
K>
R>
When you click on F, it gives you the other three.
I'm working on pressures, now, and need to get them put in using the same format as above. I have information from 2 links, http://en.wikipedia.org/wiki/Pressure and http://wiki.xtronics.com/index.php/Pressure_Conversion_Table . Just trying to see if anyone else has suggestions on what should be included, what I can ignore, etc.
So for pressure, I have the options of:
Pa
bar
at
atm
Torr
psi
I will see about adding these in and will check back if anyone else has anymore that I should add to the pressure section of the conversions
Edit:
All pressure equations listed above have been added. Now I'm working on the Speed equations, but having issues finding a good table that shows common speeds and how to equate the conversions. Anyone want to help me locate this please?
MPH to KPH: 1 mph = 1.609344 kph
KPH to MPH: 1 kilometre = 0.621371192 miles
There're those. Got any others?
http://www.sutron.com/pdfs/Conversions&Calculations.pdf Found a few there, plus it does lengths and distances!
F>
C>
K>
R>
Pa
bar
at
atm
Torr
psi
Edit:
