I am trying to compile geany from source, and as far as i know you just cd into the geany folder. Then ./configure make make install. I tried to configure, but i got this.
aes@ubuntu:~/Documents/geany-1.22$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether ln -s works... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking fnmatch.h usability... yes
checking fnmatch.h presence... yes
checking for fnmatch.h... yes
checking glob.h usability... yes
checking glob.h presence... yes
checking for glob.h... yes
checking for stdlib.h... (cached) yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for off_t... yes
checking for size_t... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for gethostname... yes
checking for ftruncate... yes
checking for fgetpos... yes
checking for mkstemp... yes
checking for strerror... yes
checking for strstr... yes
checking for Git revision... none
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for GTK... no
configure: error: Package requirements (gtk+-2.0 >= 2.16 glib-2.0 >= 2.20 gio-2.0 >= 2.20 gmodule-2.0) were not met:
No package 'gtk+-2.0' found
No package 'glib-2.0' found
No package 'gio-2.0' found
No package 'gmodule-2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables GTK_CFLAGS
and GTK_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
I tried to apt-get install and yum install those last 4 packages, but it does not work. This is what i get for one, they are all the same.
aes@ubuntu:~/Documents/geany-1.22$ sudo apt-get install glib-2.0
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'gir1.2-glib-2.0' for regex 'glib-2.0'
Note, selecting 'gir1.0-glib-2.0' for regex 'glib-2.0'
Note, selecting 'gobject-introspection-glib-2.0' for regex 'glib-2.0'
Note, selecting 'libqtglib-2.0-0' for regex 'glib-2.0'
gir1.2-glib-2.0 is already the newest version.
The following NEW packages will be installed:
  libqtglib-2.0-0
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 59.5 kB of archives.
After this operation, 197 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://us.archive.ubuntu.com/ubuntu/ oneiric/main libqtglib-2.0-0 i386 0.10.1-2ubuntu3 [59.5 kB]
Fetched 59.5 kB in 2s (24.3 kB/s)
Selecting previously deselected package libqtglib-2.0-0.
(Reading database ... 202476 files and directories currently installed.)
Unpacking libqtglib-2.0-0 (from .../libqtglib-2.0-0_0.10.1-2ubuntu3_i386.deb) ...
Setting up samba4 (4.0.0~alpha17~git20110807.dfsg1-1ubuntu1) ...
Administrator password will be set randomly!
Unknown parameter encountered: "max log size"
Ignoring unknown parameter "max log size"
Unknown parameter encountered: "syslog"
Ignoring unknown parameter "syslog"
Unknown parameter encountered: "passdb backend"
Ignoring unknown parameter "passdb backend"
Unknown parameter encountered: "unix password sync"
Ignoring unknown parameter "unix password sync"
Unknown parameter encountered: "passwd program"
Ignoring unknown parameter "passwd program"
Unknown parameter encountered: "pam password change"
Ignoring unknown parameter "pam password change"
Unknown parameter encountered: "map to guest"
Ignoring unknown parameter "map to guest"
Unknown parameter encountered: "usershare allow guests"
Ignoring unknown parameter "usershare allow guests"
Unknown parameter encountered: "guest ok"
Ignoring unknown parameter "guest ok"
ProvisioningError: guess_names: 'server role=standalone' in domain controller must match chosen server role '/etc/samba/smb.conf'!  Please remove the smb.conf file and let provision generate it
dpkg: error processing samba4 (--configure):
 subprocess installed post-installation script returned error exit status 1
No apport report written because MaxReports is reached already
                                                              Setting up libqtglib-2.0-0 (0.10.1-2ubuntu3) ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Errors were encountered while processing:
 samba4
E: Sub-process /usr/bin/dpkg returned an error code (1)
I am sure its just a newbie problem, but could use some help. I did this with a couple other things, and i just gave up becaue i did not need them. I need an IDE for the final, unless i want to spend hours in a class room...
Is there a particular reason you need to build geany from source? It's in the Ubuntu repos:
# apt-get install geany
:^) I just never thought to look...
ok for future notice. What was i doing wrong? In case i ever do have to compile from source?
edit:
aes@ubuntu:~/Documents/geany-1.22$ sudo apt-get install geany
[sudo] password for aes:
Suggested packages:
  geany-plugins
  geany
Need to get 2,719 kB of archives.
After this operation, 7,717 kB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu/ oneiric/universe geany i386 0.20-1.1ubuntu1 [2,719 kB]
Fetched 2,719 kB in 21s (124 kB/s)
Selecting previously deselected package geany.
(Reading database ... 202481 files and directories currently installed.)
Unpacking geany (from .../geany_0.20-1.1ubuntu1_i386.deb) ...
Processing triggers for hicolor-icon-theme ...
Processing triggers for man-db ...
Processing triggers for desktop-file-utils ...
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf.index...
Processing triggers for gnome-menus ...
Processing triggers for doc-base ...
Processing 1 added doc-base file...
Registering documents with scrollkeeper...
                                                              Setting up geany (0.20-1.1ubuntu1) ...
 samba4
^^ Thats what i get after trying to get from repo. Its possible i am just overly tired.
You probably needed the -dev package(s) for those libraries it wanted. Most binary distributions don't install the headers for building software against libraries with the library binaries, preferring to split them into a -dev package (Arch is the only exception to that rule I know of offhand). For example, the glib-2.0 dependency would be met by libglib2.0-dev.
The big chunk of error output you're getting is unrelated to what you're trying to do; your samba package appears to be broken (and just as it says, removing /etc/samba/smb.conf will probably fix that).
ok. thanks. will attempt again after sleep.
You could also try reinstalling Samba. What OS are you using? Ubuntu?
I was using ubuntu, i removed the smb.conf and tried to install geany again. IT reinstalled samba or fixed it, not sure. and now geany is working. now to make a topic about a C++ Dice animation
<closed>
