- Utilities for the Casio Prizm (v2.1: text editor and PicoC!)
- 25 Sep 2012 02:25:30 pm
- Last edited by gbl08ma on 21 Jun 2016 03:57:19 pm; edited 15 times in total
The Utilities add-in enhances your Casio Prizm calculator by providing functionality not originally found in the OS, or by providing enhanced alternatives to existing functionality.
Download links are after the screenshots, on the "Download" section.
Features
See here: https://github.com/gbl08ma/utilities#features
Some remarks:
- Weights less than 185 KiB, saving space on your Prizm's storage memory and speeding up its transfer between calculators.
- Really fast to start up - it's usually even faster than the built-in app Run-Mat!
- It's open source (GitHub)
Download
Download g3a directly (simpler, you can even download directly to the calculator drive)
Download ZIP archive with Read-Me
Download ZIP archive for the PicoC edition - Information about PicoC
If you are planning on hosting Utilities on calculator software archives, please use the unmodified ZIP file which has the Read-Me and license files.
Still, I would appreciate you didn't host it yourself, and just linked to the above links. It makes updating easier and also lets me count the downloads better.
For sending directly to your friends' calculators, you don't need to send the Read-Me or the license.
Installation instructions
To install, connect the Prizm calculator to the computer with a miniUSB<->USB cable. On the calculator, press F1 when a pop-up appears on the screen. Wait for the USB connection to be established. When it's finished, your Prizm will appear on your computer as if it were a pendisk.
Copy "utilities.g3a" to the root folder of the pendisk (i.e., out of any folders but inside the pendisk) and safely remove it. Wait for the calculator to finish "updating the Main Memory". When it does, you should notice a new Menu item, with a Clock icon, called "Utilities".
The first time you run Utilities you'll be presented with the tny. internet media group logo and then a screen with some important notes about the add-in. You should definitely read them. You will then be guided to adjust the clock, something you'll have to do every time you take the batteries off. Don't worry, Utilities will remind and guide you through the process.
Update instructions
Copy the new utilities.g3a over the old one. Refer to the installation instructions for more details. If you used a version of Utilities older than Beta 9, see here.
Usage instructions
Everything should be pretty much self-explanatory - Utilities is made to dispense the Read-Me 🙂. Because of that, only less obvious things will be detailed here. To open the settings menu, press Shift+Menu while Utilities is running.
The calculator lock function will guide you through the process of setting a password, the first time you use it. You can contact gbl08ma if for some reason you wish to disable this function (be prepared to follow instructions in a very exact way).
The Add-In Manager only becomes available when the "Show advanced tools" setting is enabled. It is still unstable and may cause system errors. If you see a System Error, you should try pressing Menu and then 1 to try to dismiss it, or you can press EXIT to reboot the calculator. 99% of the times no data is lost or serious damage is done in the event of System Errors.
Checking for updates
Starting with the v1.2 release, Utilities includes a little function that, assuming the calculator's clock is adjusted, will remind you to check for updates after a certain date in the future. However, you do not need to wait for that message to appear. You should check for updates to Utilities periodically, to ensure you have the greatest feature pack and the most stable version. To check for new versions, you should visit this thread or the following page:
http://gbl08ma.com/casio-prizm-software/
License
The add-in is available under the GNU GPL version 2. The license text is available online at https://www.gnu.org/licenses/gpl-2.0.html
Last words
Utilities is the result of over four years of research, work and extensive testing. That said, we can't guarantee you will have no problems using the add-in or that everything will work as described. You are welcome to report problems to the contacts above, as well as modify the source code to your needs as long as you respect the license.
We hope you enjoy using Utilities as much as we did developing it. And if this add-in ever becomes useful, you just found a secret feature 😉
Original post for historical purposes: http://pastebin.com/un8i1YS9
Features
Some remarks:
Download
Update instructions
Usage instructions
License
Last words
