Ok, what I want to do is make an addin exit to menu, and when i press menu again, restart the addin?
All my attempts have simply frozen the calc. :-\
What do your attempts look like? If you use the following, [MENU] twice will leave and re-enter your add-in, but you can't easily tell that your add-in has been left:
Code: GetKeyWait_OS(&kcol,&krow,KEYWAIT_HALTON_TIMEROFF,1,0,&key);
Bdisp_EnableColor(1);
Edit: I do wonder what kcol and krow and key look like afterwards, though, and if you can use that to detect that MENU was handled.
well, mine ususally look something like this:
while (!done) {
key = PRGM_GetKey
switch (key) {
case KEY_PRGM_MENU:
done = 1;
break;
return 1
//stuff to do after re-entry to addin
But i guess my real question is, how do you get the addin to exit to menu? Is there a syscall?
No, there's no known syscall, and exiting isn't the right solution either. You need to let one of the getkey system calls handle it, hence my suggestion.
why not do:
int main() {
if (key==menu) {
exitToMenu();
void exitToMenu() {
GetKey(&key);
That would do a blocking GetKey which would allow turning off the calc, or exiting to menu, right?
