I want a computer for my room but I can't afford one is there a way to turn my ti84 into a small desktop.
Ashbad
- Guru-in-Training (Posts: 2497)
- Re: Is it possable to turn a TI84+se in to a small desktop?
- 15 Feb 2012 06:03:52 pm
If you're fine living with 70's (at most early 80's) hardware for your computer... could you explain more of what you want out of using your 84+ in place of a modern PC? Up front, I'll tell you that most things you'll want will not be there.
I just want something that will work for programming. I want the same funtionality as the calc alone would have.
Do you mean gut the insides, stick a beagleboard in it, add in the keys and a board for it, a color LCD, and load linux on it? (Note, this is not intended as an excuse to play UT in Math class)
You can buy an adaptor from TI that lets you connect it to a TV. You can get a TI keyboard for typing, but I don't know if it will even work in the program editor. Using a mouse can be done, but it isn't needed for typing
You can buy the TI Keyboard, but like AHelper I don't know if it works in the program editor or just in NoteFolio.
Raspberry PI. $35. February 20. http://raspberrypi.org/
You could use TI's official keyboard, Jerry with a USB mouse, and the TI Presenter (if your calc has a ViewScreen port).
