Do you see any errors in the error console? Which browser are you using? I'll do my best to replicate your results.
» Forum
> Cemetech Labs
AHelper wrote:
No errors, Chrome 22.0.1229.94 (Official Build 161065) m
I can send you my rom if you want.
I have my own GlassOS ROM, and I'm fully able to load the ROM, reload the ROM, reboot the virtual calculator, etc. It just doesn't get past setting up the file system, because it ends up in the interrupt handler. I can send you my rom if you want.
AHelper wrote:
KermM, do you support all of the undocumented syscalls?
I assume by undocumented syscalls you mean undocumented opcodes. I think that I do, unless you can think of one you think I'm not.
Yup, sorry, op codes. I use the ixh/ixl/iy_ ones.
So, here is what happens (and why I asked the above question):
- I make a library call to fs_format. Requires undocumented ops.
- Erase the flash normally
- Write on each page
I assume you have set a breakpoint and verified that it's not getting to the page-erasing? Or is that not the case?
Nope, didn't do that yet. I couldn't because of the bad speed of the emu before. I will try later on today. And I assume that the page erase is failing since writing already works or the execlibf fails.
<edit>
The reason why I haven't debugged is that I need a working trunk build. Since it currently fails to boot, I need to roll out a fix in order to get the function maps and asm output.
I just tried it in Chrome, and I seem to have no problems with GlassOS and jsTIfied. I see that page 0 is full of rst 38h ($FF?), so when the interrupt fires, it just keeps jumping to $38h and pushing repeatedly onto the stack.
page 0 shouldn't have ff at 0x38 as you can't write ff to reset bits
So far bugs:
To step once a breakpoint is hit, you have to clear the breakpoint, hit continue, then hit step. Not doing that doesn't step.
After you continue from your first breakpoint, no other breakpoints will be caught
Feature requests:
Step over?
Have it so that when the skin is on, you simulate the LCD contrast and such, but with the skin is off, just use greyscale - no contrast shading and such.
So far bugs:
Feature requests:
Step over?
So far bugs:
Fixed. One of the two execution paths for stepping had an extra check to see if you hit a breakpoint that was preventing progress. You shouldn't have to Continue to Step.
So far bugs:
Fixed.
Feature requests:
Step over?
Excellent idea. I'll think on how to implement that, although I have a pretty good idea.
Step over?
That would certainly save a lot of CPU time.
LDIR Bug
Upon running all.c: void flashErase(unsigned char page) __naked, the ldir command succeeds the first time. When ran again, ldir doesn't copy any data.
Dump 1:
Dump 2
IRC log
Memory dump on unsuccessful copy
Dump 1:
/** Erases a sector
* Given a page, the sector will be erased
* @warning Do not use this directly
* @param page Page in the sector to be erased
page;
#ifdef SDCC
__asm
di
ld hl,#__flashErase_start
ld bc,#(__flashErase_end-__flashErase_start)
ld de,#0xf000
ldir
pop bc
pop hl
push hl
push bc
push hl
call #0xF000
pop hl
ei
ret
__endasm;
#endif
Dump 2
void _flashErase(byte page)
char *f1 = (void*)0x6AAA; // Page 2
char *f2 = (void*)0x5555; // Page 1
byte *spot = (byte*)0x4444;
char oldpage = Port_Mem_B1;
// Dont' do something stupid
if(page > 0x67)
return;
//ASSERT(page < 0x08 || page > 0x67, "flashErase: Page out of range!");
// Electro-Disco -- Thanks PongOS!
Port_Mem_B1 = 0x02;
*f1 = 0xAA;
Port_Mem_B1 = 0x01;
*f2 = 0x55;
Port_Mem_B1 = 0x02;
*f1 = 0x80;
*f1 = 0xAA;
Port_Mem_B1 = 0x01;
*f2 = 0x55;
Port_Mem_B1 = page;
*spot = 0x30;
while(*spot != 0xFF)
Port_Mem_B1 = oldpage;
IRC log
#cemetech on 10/25 CST wrote:
[16:46] <THX1138> KermM, narrowed down why GlassOS crashes
[16:46] <THX1138> you implimented ldir incorrectly
[16:46] <THX1138> it copies the wrong data afaik right now
[16:46] <THX1138> yup, it copied garbage
[16:47] <BrandonW> That sounds like a critical issue.
[16:47] <BrandonW> Something that would've come up before now.
[16:47] <THX1138> the source couldn't have changed
[16:47] <THX1138> it is in the rom
[16:48] <THX1138> I have verified that the src is correct
[16:50] <THX1138> for ldir, hl is src, bc is length, and de is target, right?
[16:50] <BrandonW> Yes.
[16:50] <THX1138> then KermM broke it
[16:51] <THX1138> yup
[16:51] <THX1138> KermM, MAJOR problem
[16:51] <THX1138> ldir to page 81 at 0xf000 doesn't work
f000: call $390f
f003: pop af
f004: pop bc
f005: ld e,l
f006: push de
f007: push bc
f008: call $379c
f00b: pop af
f00c: pop de
f00d: ld a,$3f
f00f: sub e
f010: jr nc,$3
f012: ld l,$3
f014: ret
f015: ld l,e
f016: ret
f017: ld l,$30
f019: ret
f01a: cpl
f01b: ld h,l
f01c: ld (hl),h
f01d: ld h,e
f01e: cpl
f01f: ld h,e
f020: ld l,a
f021: ld l,(hl)
f022: ld (hl),h
f023: ld (hl),d
f024: ld h,c
f025: ld (hl),e
f026: ld (hl),h
f027: nop
f028: ld a,($50)
f02b: cp $ff
f02d: ret nz
f02e: ld de,$f000
f031: ld hl,$307e
f034: ld bc,$45
f037: ldir
f039: call $f000
f03c: ret
f03d: ld a,$aa
f03f: ld ($aaa),a
f042: ld a,$55
f044: ld ($555),a
f047: ld a,$90
f049: ld ($aaa),a
f04c: ld a,($0)
f04f: cp $c2
I need to get to that. For now, I must mention that I fixed TI-83+ (normal) support for early OSes, which expect the PC to start at 0x0000 when the calculator is reset. Later OSes deal with 0x8000, which is what the TI-83+SE, TI-84+, and TI-84+SE expect.
Uncaught RangeError: Maximum call stack size exceeded
i6_read_normal
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
z8_interrupt_fire
timer_expired
z8_step
I think this is a problem. This isn't an issue in GlassOS now. The DI instruction (at 0x38) should be interrupted...
jsTIfied keeps asking for a ROM image after I've supplied one. Cookies are enabled, and the emulator functions, but the dialog box appears every time I load the program to the emulator.
What browser? OS? It could be your browser supports DOM storage but it deletes the DOM storage periodically.
That's my thought as well. DBrak: Does it ask for a ROM every time you reload jsTIfied? Or whenever you try to transfer a .8xp program to your jsTIfied-emulated calculator?
I tried loading a Pic variable from my CSE up to jstified, and sadly, it fails to do so. :< Is the support for it not there, or could there be other issues? Had to use TILP to get the pic file from my CSE to my pc.
Support is definitely there, and I have loaded Pic variables on my own jsTIfied version before. What happens, it just displays the failed message on the right side?
Edit: Or were there Javascript errors? I recently changed how variables are sent, as you may recall, so I could have an undiscovered bug.
Page 7 of 8
