I cant get the syntax to work.
Can you be more specific? What sort of error message do you get? Were you able to open the command prompt?
I opened it. It says, "The syntax of the command is incorrect." I'm probably typing it wrong. This is what I typed, "-n <WebHub>" for Gossamer. I've tried everything. Now it says, "Received message of length 27 from server." How do I connect with my calculator?
Another problem is that my calculator won't connect to the computer.
😠 I'm frustrated. I'm banging my head on the computer screen. I am literally crying. 😢 I hate that my calculator won't freaking connect! 😠 NEED MORE HELP! I still need help please. I can't connect it to my calculator. I DON'T KNOW HOW!
Can you post the arguments that you're providing to the gcnclient as well as the full output? You can copy-paste by right-clicking in the command window, choosing "mark", highlighting what you want to copy, then right-clicking. You will then be able to paste it here.
gcnclient -n IRCHub -l SpencerB -d d -s gcnhub
.cemetech.net -p 4295That is what I put in. It says it is receiving but, nothing shows up on my calculator.
That looks good to me. Now, make sure you run that while the calculator is connected over Direct USB, connected to a port where the filter driver is installed, and when the calculator is at the homescreen.
Please don't double-post, this is the third time I've warned you.
Seriously, you can use the edit button.
^ right there, as pointed out with my awesome MS Paint skills
You know the screen of the calculator where you type in equations and whatnot? That is what is known as the homescreen
Spenceboy98 wrote:
Okay. Just making sure. It still isn't doing anything to my calculator. What is it supposed to do?
If you are at the homescreen using the Direct USB cable (not the SilverLink, right?) and you run the gCnClient, it should say "connected" and then not do anything until you start up Gossamer or CALCnet Chat or whatever program you're trying. -
Spenceboy98
- Minor Calculator Deity (Posts: 1063)
- 15 Jan 2012 02:04:34 pm
- Last edited by Spenceboy98 on 15 Jan 2012 02:20:24 pm; edited 1 time in total
Nothing is happening. ☹️ It's not even registering on TI Connect.
are you using a USB cable, if not then that could be the problem
Wait, TI-Connect shouldn't be a component in all this. Are you saying that your calculator isn't registering in TI-Connect at all, ignoring all the gCn stuff? Register to Join the Conversation
Page 2 of 3
