I suddenly have this error: The current transfer failed. A retry may be successful. (8C010000). I click retry a million times, unplugging and replugging the cord and calculator as well, cleared ram and did a garbage collect. (Btw I have a ti-84 silver edition.) Nothing at all! Please help! - Cheers! 🙂 (What good games are for the Ti84 silver edition?)
Combatstx, you have unfortunately encountered one of the many, many bugs that the combination of the TI-OS and TI-Connect using the Direct USB cable produce. On my current laptop, all three USB ports and my TI-84 Plus C Silver Edition produce similar errors, and each time you try to start a transfer, Windows decides the attached USB device has malfunctioned. This leads me to believe that TI-Connect is not the only part of the problem. At any rate, have you considered giving TILP II a try?
Also, with regards to great games, check out some of our favorites, and make sure you also have Doors CS. 😉
Arghh... TiLP II can't find my device! Any other options? ☹️
Did you use another cable? Did you use other USB ports? Did you try another PC?
I would recommend spending the $13 on this
http://www.ebay.com/itm/TEXAS-INSTRUMENTS-TI-GRAPH-LINK-TI-GRAPH-LINK-USB-CABLE-LINK-NOS-/200998095941
I have -never- had a connection issue utilizing this cable.
doesnt Tilp require a filter driver? did you install it?
Yeah, the SilverLink will invariably solve your problems, and it works with all newer calculator models including the TI-84 Plus C Silver Edition. Of course, it would be nice if the Direct USB link would work more reliably. 🙂
