While you can't actually see it unless they're moving, the entire leg structure is split down the middle, so the legs can move independently of each other.
Also:
Skadoosh
Keep in mind the other two droid heads fall below the top of the bounding box. Also, Wiggy just altered the boxes to make them as deep as they are wide and identical to the crouch bounding box x and y values to nullify an exploit that allows players to phase through walls.
