I couldn't find any documentation, and Kerm said to create a topic, so here it is.
I'm mildly interested in writing my own methaub and some virtual hubs, but to do that I need documentation on the protocol between gcnclient and the metahub.
I'm not sure where to start, so I'll be beginning at the beginning, I guess.
What does gcnclient say when it first connects, identifying the virtual hub it wants to connect to and the local hub name?
You should take a look at my C# calcnet library. It should give you some idea of the protocol and everything. I can explain stuff if you have any questions on it.
I'll look into it. Thank you.
I'll almost certainly have some questions since I want to create a metahub while what you have is a client, but it should still help 🙂
Just to give you a basic idea, the protocol works something like:
1) gCnClient connects to gCn metahub
2) gCnClient specifyies a virtual hub name. gCn metahub adds that IP:port:clientname to the virtual hub's endpoints ('J' message)
3a) When calculators connect to the client, it tells the metahub that there's a new connected calculator ('C' message)
3b) A broadcast message gets sent from one calculator to every other calculator on the virtual hub ('B' message)
3c) A frame message is sent from one calculator to one other ('F' message)
4) There is no current way to remove a calculator without disconnecting the client from the virtual hub, which I didn't realize until just now.
For frame messages, can they only be sent to calculators that the virtual hub knows are there? (It might be there, but the virtual hub might not know it, if the calc is connected but has never sent a message.)
The client does not prevent a frame from being sent to a nonexistent calculator; the clients only track their local calculators, and do not know all the calculators on the virtual hub. However, as the hub knows all calculators present, it will silently drop messages sent to unknown endpoints, as it would have no idea which client to forward the frame to. The protocol requires that all present calculators announce themselves. Oh, and since you're looking to make a service bridge, I should mention that by convention bridges take the address $AA,$AA,$AA,$AA,$AA.
