I decided I would like to learn C for the Ti 84 CE. Would someone enlighten me on what is necessary to begin? I am confused on something - I thought the TI 84 ce supported c programming, so why are the libraries necessary?
It only supports C programming because of Mateo's libraries. Otherwise, you are limited to ASM and TI-Basic (and other languages like ICE, and C, with use of external items)
Support the community by joining MyCalcs for free! Co-founder of TI-Toolkit.
So, If I want to program in C, I need Mateo's libraries. Correct?
And, are there any c tutorials or documentation?
Yes, and I believe there are some on the git page.
I'm not an expert, so you might want to look it up (try looking it up on the forums, as google will give unrelated results.
Yes, you need Mateo's libraries which can be found here. https://github.com/CE-Programming/libraries
I believe there is documentation in the download.
- MateoConLechuga
- Official Cemetech Lettuce Manager (Posts: 3890)
- 02 Mar 2017 08:59:06 pm
- Last edited by MateoConLechuga on 02 Mar 2017 09:06:01 pm; edited 1 time in total
I would just like to reiterate they are not mine; but many in the community have helped to make. No, the libraries are not necessary to make C programs, but are highly recommended. The point of the libraries is to perform common routines such drawing sprites, working with files, and even using BASIC variables.
The main documentation that will be the most helpful to you is located on the wiki pages:
https://github.com/CE-Programming/toolchain/wiki
Of course, the header files for all of the library functions contain documentation throughout. (You can find them here). Also, the many examples in the toolchain also are heavily commented to help you start out.
Feel free to ask any questions, and grab the toolchain here: https://github.com/CE-Programming/toolchain/releases
(I usually tend to write the wiki based on the questions I see, so if you have any real concerns as you begin feel free to post so I can try to make it easier to understand)
Of course, the header files for all of the library functions contain documentation throughout. Also, the many examples in the toolchain also are heavily commented to help you start out.
We call them yours as a) you tend to do things like that and b) it's easier to attribute things to a single person.
*Creates shortcut for that ^^
Thanks guys. I feel like learning C right now to see if I like it. If I do, I will probably get a CE. I'll just use CEmu for testing the programs. Is there a windows program that allows you to enter c or similar code, and, when you hit compile, converts it into asm for the TI83+?
EDIT:
Could I have the links to everything I need to begin programming?
EDIT:
EDIT:
EDIT:
I am not sure that C works with the 83+
The wiki pages have everything you need to set up
Ok, so I follow the instructions to compile demo_0, after running the windows setup file, etc., but i get a message in the terminal (command prompt) that
'make' is not recognized as an internal or external command, operable program or batch file.
so, uh, you need to set your path. https://github.com/CE-Programming/toolchain/wiki/Setting-up-environment-variables
and read this: https://github.com/CE-Programming/toolchain/wiki/Building-your-first-program
You have to start a new command prompt
The reason you need to open a new command prompt after the installation is because it doesn't pick up the new PATH variable (I think).
https://ivoah.net
How do you prevent it from blocking it? Is there any step by step, page by page tutorial to teach the commands?
Probably this helpful page. Remember, google is your friend
Yes; the main ones for graphics and files and others can be found on these pages:
Tutorials/wiki: https://github.com/CE-Programming/toolchain/wiki
Function documentation: http://ce-programming.github.io/toolchain/files.html
Also, all of the examples that come with the toolchain are fully commented and explain what is going on
OK, I tried turning off the Smart Screen, but I tried again and it still displayed like this:
thanks MatthewWithLettuce!
C:\Users\Family\Documents\Calculator Work\Downloaded Programs\C Coding\examples\hello_world>make
So first off, it would work better if you remove the spaces in your path. (I know on linux this causes issues with Environment Variables)
Actually, have you run the windows installer?
Unicorn wrote:
Yes, I do believe I have
» Goto page 1, 2 Next
