Hi! I've got a lot of questions from my experiments, so let's get started!
First, How could I create a snippet of code that detects whether there is a picture saved in a slot and if it is unarchived so that the program it is in doesn't crash when it trys to open an inexsistent picture.
Second, I experimented with sum(3 and sum(0 in this program:
Code: :sum(3)->L1
:sum(0,L1
:Disp Ans
:Pause
/other code
This led to a display of ".D" The list stored in L1 was {-3 -4 -10}
Baffling, in my mind
Third, I was experimenting with radio buttons (because I love booleans ) and wrote this program:
Code: :sum(9
:sum(7,0,255
:sum(7,1,0000000000,"TEST
:sum(7,10,5,5,"TEST",0,"CHOICE A"
:sum(7,10,5,55,"TEST",0,"CHOICE B"
:sum(7,10,5,25,"TEST",0,"CHOICE C"
:sum(12,5,5,1
:sum(10
:Pause
I have a few questions about this code:
1)Where is the large window I put in (sum(7,1))
2)can I put a button or hotspot programming after the booleans that somehow says to end the program when clicked? if so, how? (the sto> button did work, I just want to find an alternative )
3)When I ran the code, I couldn't get one to automatically be selected (you should just be able to put a zero instead of a one after the "TEST" label, right?)
4)Also when I ran the code, The descriptions for the buttons all said "TEST" instead of Choices A, B, or C. However, the radio buttons function exactly like they're supposed to, only one being selected at a time.
5)What syntax errors or mistakes (if any) did I make in the code?
I'm going to continue to experiment. Hopefully I won't brick my calculator...
