Question: I was experimenting with some BASIC commands, including a simple GUI mouse (specifically sum(6,startX,startY) ) and soon after that, the program started to freak out and giving me sintax errors on random pieces of code like "end" and so on. What happened? I guess the question I should ask first, is what the heck is a GUI and how does it work?
I learned about the command
here.
GUI is Graphical User Interface. You use GUI's everyday from your computer to your phone. An example of a non-GUI interface would be a command line system, such as Command Prompt/Terminal.
I won't get into how they work, leave that for the big guys here
Also, were you running your program from the TIOS Home Screen or from within DCS7?
Good to know; it does appear you were using the routine correctly. And what calculator were you using?
Also, do you need any other clarification about GUI's?
TI-84+
Pretty much everything...
What the heck is the "Push GUI Stack and all that...
http://dcs.cemetech.net/index.php?title=DCSB_Libs
I strongly recommend you take a look at the PDF that comes with the Doors CS SDK, or at least glance through this:
http://dcs.cemetech.net/index.php?title=GUI_API
It would also be helpful if you posted your code using
SourceCoder.
I deleted it in case it crashed my calculator. I'm treading on uncharted ground, you know and I needed it for exams, Sorry.
basically, the code went
:sum(6,20,20)
:sum(13,8,8,"Test","F8888888F8","Pictest+Quit","PTQU")
:lbl PT
/some code
:lbl QU
:Stop
The program pretty much gave a syntax error for every line after a label.
SourceCoder.
Or Tokens!
Can't use tokens, I have a mac.
Yes you can. Install Mono.
I don't want to. It takes up memory and I hate it when my computer runs low on memory.
And I'm too lazy.
If Mono is causing your computer to run low on memory, you need a new computer.
Unused memory is wasted memory.
Anyway...
What the heck is the "Push GUI Stack" and all that...
Basically, where can I find a good tutorial on GUI stuff?
And, of course, check other people's help topics that pertain to the GUI Stack.
Let me repeat myself from before:
:sum(6,20,20)
:lbl PT
/some code
:lbl QU
:Stop
sum(6 is the mouse, right? It says, that you need GUI elements before the mouse, at least a frame/big window/small window.
sum(6 is the SimpleGUIMouse, which you can use without any GUI elements on the stack.
The non-simple GUIMouse, sum(12, requires the normal DCS GUI Stack stuff such as a container and other elements before the mouse is called.
Which is why I started with the simple one, since I don't understand what I need to do for the complex.
