you jump to the Address in HL before even loading something into it the other Correct2: and labels past it are never called if you press up.
No, he's doing it right. The real problem is that bcall(_getCSC) destroys HL.
Oh, it does? =/
Can I use push hl/pop hl?
technomonkey76 wrote:
Oh, it does? =/
I think that would work. Also, be careful after you run AllCorrect, because the program will return to the loop with an undefined value in HL.
I personally never really use jp (hl) due to no conditionals as arguments or other customizations. a JP ADDRESS in your code would be much better and easier to debug than jumping to the somewhat-unknown value of HL.
It's a very nice tool if you use it correctly. This program is a good exercise in its use.
Okay! The program finally works! Thanks for all your help, fellow Cemetechians! I will change Pastebin so it has the final version of the code right now.
well, as long as it works, great sorry if I caused any confusion, I just rarely use Rom calls so I can use that as my excuse that I didn't know they usually destroy HL
It seems that you are getting quite adept at z80 programming technomonkey you're a pretty fast learner, like aeTIos. Keep it up! you're already learning it faster than I did the 3rd time I tried XD
It seems to me that Techno is learning very fast indeed, keep up the great work. Ashbad, when in doubt, assume that bcalls() (and calls, for that matter) trash everything, and then look at the relevant documentation (the TI Routine Reference for bcalls, the DCS SDK for ASM libraries, your own code for your own calls) to determine what actually gets destroyed.
Thanks, Kerm and Ashbad! I need to change line 23 to a more advanced routine to avoid RAM leaks now, however. I just learned that _PowerOff should only be used with apps due to the copying of the program to $9D95. Oh well.
Edit: Google found me Reply 23 by thepenguin77 at http://ourl.ca/97495!
Output $02 to port $10 to turn off the screen manually, but remember to send $03 to port $10 to turn it back on
here is example code:
This will keep it off until you press enter, as a crude example
EDIT: not the same effect as PowerOff, but pretty darn close
LD C,$10
OUT (C),$02
PUSH BC
BCALL getCSC ;Evil BCALL! but used for simplicity ;)
CP skEnter
JP NZ,{-1@}
POP BC
OUT (C),$03
Errr, what? That's not the right way to do it at all, because you'll be wasting the battery in the loop. You want to enable interrupts with the [on] key set as a valid interrupt trigger, then halt to save battery.
Code? Obviously I'll be using the iy flags, but I'm not good with interrupts yet.
Off:
ld a,2
out ($10),a ;turn off screen
res OnInterrupt,(iy+OnFlags)
call debounceon
call calcAndStore_OSChecksum
im 1
ei ;enable interrupts
ld a,1 ;enable ONLY [ON] key, no linkport wake
out (3),a
halt
di
mode on halt
ld a,%00001011
out (3),a
ld a,3
out ($10),a ;turn on screen
debounceon:
ld b,16
debounceoninner:
in a,(4)
bit 3,a
jr z,debounceon
djnz debounceoninner
ret
Off:
ld a,2
call debounceon
im 1
out (3),a
halt
di
mode on halt
ld a,%00001011
out (3),a
ld a,3
debounceon:
ld b,16
debounceoninner:
in a,(4)
bit 3,a
jr z,debounceon
ret
What is the code for calcAndStore_OSChecksum?
I think that calculates the RAM checksum, like the TIOS does so that it doesn't clear RAM when starting the program again.
That indeed would be a great way to do an actual shutoff -- however, what I posted can be used as more of a "Teacher Key" code as it is extremely small, and a full-out shutoff is not always necessary. However what Kerm posted should be used if you have the proper space -- but in some cases you might not, and when you don't and the turn off is meant to be a few seconds I would recommend my routine.
Deep Thought wrote:
It seems fast enough. Definitely not "a few seconds"
Well, if you're BSing your teacher for a few seconds is what I meant I doubt you'll be in Teacher Mode for more than ~10 secs.
Not the speed of the actual routine.
Page 4 of 5
