The short is indeed always 16 bits on the Prizm, and I think there are very few platforms that would be awkward enough to have a short that is not 16 bits wide, I hope.
The one platform that I am most familiar with that doesn't use 16-bit shorts is the PDP series of minicomputers. Some of those used 18-bit shorts and 9-bit chars.
But even that shouldn't be too awkward to use in C unless you do a lot of heavy bit twiddling. As a bonus, you get 36-bit longs, which have 16 times the range as 32-bit longs (±32 billion).
- KermMartian
- Site Admin (Posts: 64080)
- 18 May 2011 01:06:30 am
- Last edited by KermMartian on 22 May 2011 12:22:32 pm; edited 1 time in total
Ah yes, the infamous 9-bit byte PDPs. Sadly, it seems that an inordinate number of mt programs do end up doing odd bit-twiddling tricks; maybe I'm (too) used to working in low-level languages. Anyway, getting this show back on-topic, I have a CopySpriteMasked routine that treats one specified color as "transparent":
CopySpriteMasked
CopySpriteMasked
void CopySpriteMasked(const char* data, int x, int y, int width, int height, int maskcolor) {
char* VRAM = (char*)0xA8000000;
VRAM += 2*(LCD_WIDTH_PX*y + x);
for(int j=y; j<y+height; j++) {
for(int i=x; i<x+width; i++) {
if ((((((int)(*data))&0x000000FF)<<8) | ((((int)(*(data+1))))&0x000000FF)) != maskcolor) {
*(VRAM++) = *(data++);
} else { VRAM += 2; data += 2; }
VRAM += 2*(LCD_WIDTH_PX-width);
Generate pseudo-random number
input - 32bit integer for upper and lower bounds
this is based on the famous '128bit shifting' technique, and is considered highly random enough.
int Rand32(int lower, int upper) {
static int a = 123456789;
static int b = 362436069;
static int c = 521288629;
static int d = 88675123;
int t;
t = a ^ (a << 11);
a = b;
b = c;
c = d;
return (d = d ^ (d >> 19) ^ (t ^ (t >> 8)))%upper + lower;
it is based on this: http://en.wikipedia.org/wiki/Xorshift
also,
Test a pixel of CURRENTLY rendered VRAM image
inputs: X and Y position
outputs: short holding color value
also,
short GetPXColor(short x, short y) {
char a = *(y * LCD_WIDTH_PX + x * 2);
char b = *(y * LCD_WIDTH_PX + x * 2 + 1);
short c = a << 8 + b
return c;
Not bad. My getpoint looks like this:
//gets color of point (x0, y0)
int getpoint(int x0, int y0) {
VRAM += 2*(y0*LCD_WIDTH_PX + x0);
return ((((int)*(VRAM)) << 8) & 0x0000FF00) | (((int)*(VRAM+1)) & 0x000000FF);
hmm -- would the addition I do have any difference when compared to your or-ing? could it possibly interfere with the topmost 8 bits?
More importantly, I fail to see why you're both using char* when accessing 16-bit chunks in the native byte order. Provided there's no odd alignment requirement on VRAM (which seems unlikely, given that GetVRAMAddress returns a void*), this would be a little faster:
And maybe if you want to extract color channels from a pixel..
unsigned short getpixel(int x, int y) {
unsigned short *VRAM = (unsigned short *)0xA8000000;
return *(VRAM + (y * LCD_WIDTH_PX) + x);
typedef struct {
unsigned r : 5;
unsigned g : 6;
unsigned b : 5;
} color_t;
color_t getpixel(int x, int y) {
return (color_t)*(VRAM + (y * LCD_WIDTH_PX) + x);
Ashbad
- Guru-in-Training (Posts: 2497)
- 22 May 2011 12:52:33 pm
- Last edited by Ashbad on 22 May 2011 05:25:31 pm; edited 1 time in total
well you can't blame me, I'm a C newbie, I wasn't really aware you could do that *turns to Kerm*
also in that case, new routine:
Invert Colors in Rectangular Area
inputs: shorts for x position, y position, length, and width
outputs: look at your screen! (if you actually render it)
void InvArea(short x, short y, short height, short width)
for(short a = 1; a>width; a++) {
for(short b = 1; b>height; b++) {
*(b + y * LCD_WIDTH_PX + a + x + (VRAM++)) ^= 0xFFFF;
typedef struct {
unsigned r : 5;
unsigned g : 6;
unsigned b : 5;
} color_t;
What's with the Getpixel syscall? You could just read the word straight from memory.
That's exactly what we're doing
that's why ours are called 'GetPXColor' and 'getpoint' and Tari's was just an example he made in ~30 seconds, to show us a point.
GCC will optimize it for us. Plus, the way you did it doesn't specify it as a pointer, or size of return.
Well, the point is that (0xA8000000+(384*Y)+X) won't point to the proper word. You have to account for the 16 bit color size, which requires ROTL X (or X*2).
Ah, so C expands the arithmetic?
It seems unnecessarily complicated to force to programmer to remember types, but it's convenient for source size I suppose.
EDIT: Since Ashbad posted his RNG, here's an LCRNG in [partially] optimized Assembly.
The answer is in R2, if you care to extract it.
SH3 Assembly:
MOV R2,R3
SUB R0,R3
MOV $20,R4
DIV0U R0,R1
Startdiv:
ADD $FF,R4
DIV1 R0,R1
TST R4,R4
BT/S Startdiv
ROTCL R2
DMULU.L R2,R3
STS MACL,R3
ROTR R0
BF/S LoadX
MOV $17,R3 // Load A
rngStart:
DMULU.L R1,R4
MOV.L @(dd*4+PC), R0 // Load M
STS MACH, R2
MOV R2,R3
SUB R0,R3
MOV $20,R4
DIV0U R0,R1
Startdiv2:
ADD $FF,R4
DIV1 R0,R1
TST R4,R4
BT/S Startdiv2
ROTCL R2
DMULU.L R2,R3
STS MACL,R2
RTS
$05F5 E101
LoadX:
MOV @(dd*4+PC),R1 // Load X_0
BRA rngStart
NOP
$02D6 3A86
first custom test routine here
Print Custom Character
inputs: an x position, a y position, a bit mapped image of the character, color to draw the character, if it is to draw white in non-mapped spaces, and the dimensions of the character
EXAMPLE BIT MAPPED CHARACTER (the letter A):
[0,0,1,0,0]
[0,1,0,1,0]
[0,1,1,1,0]
[0,1,0,1,0]
[0,1,0,1,0]
outputs: look at your screen (unless you don't render it)
[0,0,1,0,0]
[0,1,0,1,0]
[0,1,1,1,0]
[0,1,0,1,0]
[0,1,0,1,0]
void PutCustC(*bool map, short x, short y, short width, short height, short color, bool DrawWhite) {
short* VRAM = (short*)0xA8000000;
VRAM += (LCD_WIDTH_PX * y) + x;
for(short a = 0; a>width; a++) {
for(short b = 0; b>height; b++) {
if(*(y + b * width + x + a + map)) { *(VRAM++) = color; }
elseif(DrawWhite) { *(VRAM++) = color; }
else { VRAM++; }
VRAM += (LCD_WIDTH_PX-width);
» Goto page Previous 1, 2, 3, 4 ... 10, 11, 12 Next
Page 3 of 12
