By popular demand, I've decided that the first game that I will attempt to make for the Casio Prizm in C will be a port of Obliterate 1.0, my scorched earth / tanks-style game for the TI-83+/84+ series. C is going to make my life so much easier in terms of math, the AI, etc. I'll still have to deal with fixed point (no FPU in a calculator??), but it's gonna be fun, I think. I upgraded SourceCoder to be able to generate sprites and images in the 16-bit Prizm image format (take note, Prizm coders!), and I've mocked up the Obliterate icon and title screen and successfully compiled it onto my Prizm. I'm afraid that the photo doesn't do it justice at all, so I also uploaded the raw titlescreen image.
souvik1997 wrote:
This is going to be awesome, Kerm! I <3 your title screen picture.
Thanks very much! It looks quite awesome on the LCD of the Prizm; I'm happy how it turned out. I sorta sidestepped the fact that the OS wants to draw a border on the sides and the battery icon at the top by basically freezing it; I'm going to have to figure out a getkey call that doesn't do that. I'd appreciate any feedback if you Casio hackers have encountered this issue before. Qwerty.55 wrote:
You should probably disable the interrupts.
Ah yes, that would probably do the trick. What about the getkey() function; would that still work properly, if you happen to know offhand? Scout, true story. And I also need to compress that titlescreen somehow; 160KB of image data is a lot.
I love this title screen, one of the best I have ever seen on a calculator. Gonna be awesome on a 16-bit color screen.
Thanks very much, I appreciate the complement! I hope that the game will live up to your expectations. KermMartian wrote:
Ah yes, that would probably do the trick. What about the getkey() function; would that still work properly, if you happen to know offhand?.It should, as the keyboard is memory mapped. I imagine the OS just reads the relevant memory locations as soon as you call it.
comicIDIOT wrote:
I love the vertigo inducing calc photo
Sounds like a fun project to get gCn to the Prizm as well!
Yeah i told Kerm to get the Prizm on GCN when in IRC, i am not sure if he seen me say it or not.
Great job Kerm. the more of this i see the more i want a Prizm
oh dear. I do think the nspire has been pwned in various places by the prizm
that is it, I am getting a prizm, too many good programs are being made.... this is the first program that will go on my prizm
ComicIDIOT, that's because it's hard to take a photo of this type of LCD normally, because you can't see any colors. As it is you can barely see them. Madmax, don't worry, it something I've been planning for a while. but it's a more advanced problem once I learn more about SH3/4 ASM and the link hardware in the Prizm.
Kerm, the link hardware in the processor isn't the link hardware used to connect to the link ports or the USB.
That's fair. I don't know anything about any of the link hardware though, so I have no preconceived notions. Qwerty, maybe you know: how can I voluntarily cede control back to the Menu? As if the user pressed Menu? Alternatively, can you help me learn how to look through GetKey() to see how it does it if you don't happen to know?
Well, my point about the link hardware not being the documented stuff means that it's undocumented
Also, it's very easy to return control to the menu, although I'm not sure how conducive compiled C is to it. Basically, when the program is loaded, the OS stores the address to return to in a register called PR. To return to this, you need to push that register into PC. This is accomplished with the RTS instruction. However, using subroutines destroys PR, so you need to push it onto the stack. Here's the code to return:
The hex, if you'd like to insert it directly, is
I'm not sure how you would end it with C. It'd be whatever you use to end subroutines.
As for the Getkey() routine, you first have to have an OS dump. Once you have that, you have to figure out the address of the code, which is kind of complicated. Then you can look at the code in the OS and try to figure it out, which is made more difficult by the fact that it's spaghetti code.
You could do that or just recognize that the keyboard is memory mapped to specific bits between A44B0000 and A44B000A and just read those.
STS PR,R1
MOV.L R1,@-R15
<rest of code>
MOV.L @R15+,R1
LDS R1,PR
RTS
012A
2F16
<rest of code>
6F16
412A
000B
Ashbad
- Guru-in-Training (Posts: 2497)
- 17 Apr 2011 05:23:50 pm
- Last edited by Ashbad on 17 Apr 2011 05:27:22 pm; edited 1 time in total
wow, the title screen does look impressive ^-^ it can still be worked on (spritist sayings FTW) but it does a great job atm.
The tank icon works for now too -- but I think there should be some logo on it or something -- that's just my feeling It does look great, but for the flavor of title screen you have, they don't taste perfect together. I would say either add a logo to it, or cartoonize it, or both before final release -- however, coding IS most important
Ashbad, if I were to show you the tank icon on the Prizm homescreen, you might change your mind; I think it looks pretty snazzy if I may say so myself. Elfprince, eventually, but this is going to be a single-player AI version to start with.
» Goto page 1, 2, 3, 4 Next
Page 1 of 4
