OK, that's good. In retrospect, I see that I can write this independently of that, but it will still help with speed.
Fully-implemented USB gCn code in Doors CS! I have this wonderful bit of awesomeness now:
Now I need to shoe-horn this into a client, ideally the gCn client. What can I do to combine filter driver + Jonimus' code, and where is Jonimus code? Will it work on each OS?
Page 0 is 16381 bytes long (3 bytes to spare)
Page 1 is 16334 bytes long (50 bytes to spare)
Page 2 is 16122 bytes long (262 bytes to spare)Now I need to shoe-horn this into a client, ideally the gCn client. What can I do to combine filter driver + Jonimus' code, and where is Jonimus code? Will it work on each OS?
đ¯
That is awesome, I cannot wait for the client side stuff to come out, then I can play oblit at school đ
Well, be aware that you still need sufficient permissions to install the filter driver, Qazz, which might not be possible depending on how locked down the computers are.
Hmm, what do you mean? I have full permission of my computer O-o
oooooohhhh, ok, I see, sorry about that
darn,that sucks, I was hoping that my time in the computer lab would be more fun then đ
Thanks for that, comicIDIOT. đ Qazz, exactly what comicIDIOT said. And let's all give Merth a huge round of applause for working hard on a C# gCnClient that supports direct USB this evening. đ
elfprince13 wrote:
Very nice work. Will I get an updated elfprince edition when you come to visit?
But of course! I'll get an opportunity to update both the Elfprince and Merthsoft editions, as a matter of fact. đ Merth and I are currently on Skype, working through all the pain of issues with the client; I'm doing my best to cross my fingers and hope that not too many of the problems are on my side.
add me to the convo =) I'm doing some physics homework, but if you're still going when I get home I can help too.
After I get some savings back and purchases acquired I'll be willing to test any OS X gCn clients đ
Oh... It just occured to me that I won't need the microcontroller to use this anymore, I'm in for testing as well, under Ubuntu 32 bit and Windows7 32 bit.
Merth devoted at least three hours this evening to some great and very helpful work, including throwing together a basic Direct USB gCn client in C#. Unfortunately, all is not yet right. The client is shaping up, but receiving frames seems to have some issues. I'm working on trying to track down the problems. I'm hoping it's nothing too major, because as mentioned, I'm dealing with exactly three bytes free on Page 0. âšī¸
Ok so what do we need for a C port of the client? A chance to view the code for your arduino based setup would be great and help me there a lot.
Oh sure, not a problem at all. I think (based on what Shaun was saying) that we just need a way to use the filter driver with it. I've sent along the code to you via Skype.
Ok so looking through your code here I see what needs to be done.
From the looks of things you are just polling the device for data with a 5000ms timeout in usbhidGetReport and trying to send to the device in usbhidSetReport with the same timeout. All that is needed is to change the usb_control_msg lines in those is to use usb_bulk_read or usb_bulk_write respectively. The syntax is a little different as some of the extra control stuff isn't needed but I can write that up rather quickly.
The device is actually being found and enumerated in usbhidOpenDevice and you could either just use their Linux code there or I have a more or less drop in for that as well which will pass you a usb_device_handle for the first TI-84+/SE it finds.
Here is what I hacked together while half asleep just before bed, let me know if you see something blatantly wrong with it but as far as I can see it should work for you. Just plug in the functions where they are needed in your code and it should be all good. I can't really test it but its based on my code from the test programs I made so I don't think I did anything to stupid.
http://jonimoose.net/calcstuff/directusb.c
Edit: Note this code should work on all OS's with libusb-0.1 support including libusb-compat 0.1 and the Windows libusb0.sys/libusb0.sys filter.
Eidt2: Kerm text me in the morning if you have questions as I stayed up till 2 to work on this and I really should be getting up earlier than I did today to do stuff.
Page 6 of 8
