Definitely. Assuming there aren't any labels in between, just change Lbl B to a While 1 or something, get rid of the Goto s, and add an End to match the While .
Another small optimizations:
You can eliminate the ending parentheses. You could also try pulling out the extra 4, but that would require an extra parenthesis, so there's no point.
:X-4(A=24)+4(A=26)->X
:Y+4(A=25)-4(A=34)->Y You can eliminate the ending parentheses. You could also try pulling out the extra 4, but that would require an extra parenthesis, so there's no point.
:X-4(A=24)+4(A=26->X
:Y+4(A=25)-4(A=34->Y
ahhh. I see. thanks! Now, since this has pretty much turned into a tutorial, I'll ask another question: How do I eliminate memory fatigue? Whenever I create games with graphics, They get fatigued very fast. How can I get rid of that?
Those are what we have been calling memory leaks. The way to avoid them is to not Goto out of any construction that ends in End, including Then/End, For/End, While/End, and Repeat/End. The TI-OS will be constantly looking for the End and never finding it, and the more you repeat the leak, the more Ends the TI-OS needs to look for (but never find).
alright and now as i was creating an advanced menu, I tried to run it. However, it flipped out on the second line of programming. Here are the first few lines:
:Clearhome
:0->x (this is where it got stuck as a syntax error)
:3->Y
:Lbl A
(etc)
this is after it freaked out on the DCS thingy you can do at the top (which I cant figure out a pattern, if you can help me there too
and changed Delvar X to 0->X.There seems to be no reason for this glitch. All my other programs work fine (created by me and otherwise). The glitch started after I finished creating the advanced menu.
:Clearhome
:3->Y
:Lbl A
(etc)
1) Uppercase X or lowercase x? If it's a lowercase x, that's your problem. Also, the command is ClrHome, not Clearhome.
2) The DCS thingy: you mean the icon and header?
Those are what we have been calling memory leaks. The way to avoid them is to not Goto out of any construction that ends in End, including Then/End, For/End, While/End, and Repeat/End. The TI-OS will be constantly looking for the End and never finding it, and the more you repeat the leak, the more Ends the TI-OS needs to look for (but never find).Wait. I know memory leaks occur in many basic programs, but could you clarify on that Kerm? I don't really undertsand fully at what you're trying to say.
nevermind. I've got it figured out. forgot "then" and "else" commands, as well as a couple "end"s.
Also, yes, the icon thingy. you know:
::DCS
:10294DKFM000O40
or however that works...
Is this mirage compatible? or do I need to have a separate line of code for that?
and so how can I eliminate that? there are no other options I can think of.
::DCS
:10294DKFM000O40
Well there is a section in the Doors CS readme (pdf) that tells you how to creat MOS/Doors Hybrid heading. But I believe that the header is compatible with both? Anyhow I don't really think you need it to be compatible with Mirage OS since Doors is already stable, and widely accepted and used.
::DCS
:10294DKFM000O40
::DCS
:10294DKFM000O40
It's all listed here: http://dcs.cemetech.net/index.php?title=BASIC_Header#.22Hybrid.22_MOS-DCS_Header
Any header for DCS is compatible with Mirage, unfortunately. DCS shows all programs by default, though, so just get rid of the header if you want it to show up in DCS but not Mirage. But then you won't be able to use icons.
As Deep Thought astutely mentioned, there is a hybrid header specifically designed to make your programs recognizable by both MirageOS and Doors CS, have a Doors CS icon, and have an icon both shells understand. I have no idea why you'd want to be using MirageOS, though.
I want it to be mirage compatible because the people in my school are too stupid to use it.
Oh well. Their loss.
and I was more hoping along the lines of how that works, You know, what each letter and number put in your icon. Any list of that?
bspymaster wrote:
so there are no lists?
MirageOS doesn't support icons, but Doors CS does. There are tutorials on how to convert icons to hexadecimal (the letters and numbers). What do you mean that your classmates are too stupid to use DCS? There's nothing challenging about it... KermMartian wrote:
MirageOS doesn't support icons, but Doors CS does. There are tutorials on how to convert icons to hexadecimal (the letters and numbers). What do you mean that your classmates are too stupid to use DCS? There's nothing challenging about it...It's probably because they follow outdated YouTube tutorials that tell viewers to use MirageOS.
Well, that's why we need to start making some counter-tutorial videos! I should try to make this a more organized project, actually; who's in?
I am!
souvik1997 wrote:
I am!
Page 3 of 4
