I've been having the hardest time trying to get this code to work. I tried to take the pseudo-code from wikipedia and turn it into C++ code I can use for a project. bufPixel() draws a pixel on (buffer,x,y with attributes). When it draws the line, it appears to only draw straight down each time, as in, no matter what line, it will always draw a slope of 1 or -1. Thanks in advance.
void bufLine(CHAR_INFO* buffer,short x0,short y0,short x1,short y1,WORD attributes)
        CHAR_INFO letter;
        letter.Char.AsciiChar = ' ';
        letter.Attributes = attributes;
         bool steep = abs(y1 - y0) > abs(x1 - x0);
         SHORT a;
     if (steep)
                a = x0; x0 = y0; y0 = a;
                a = x1; x1 = y1; y1 = a;
     if (x0 > x1)
                a = x0; x0 = x1; x1 = a;
                a = y0; y0 = y1; y1 = a;
        int deltax = x1 - x0;
        int deltay = abs(y1 - y0);
        float error = 0;
        float deltaerr = deltay / deltax;
        int ystep;
        if (y0 < y1)
                ystep = 1;
        else
                ystep = -1;
        int y = y0;
        for (int x = x0;x < x1;x++)
                if (steep)
                        bufPixel(buffer,y,x,attributes);
                else
                        bufPixel(buffer,x,y,attributes);
                error = error + deltaerr;
                if (error >= 0.5)
                        y += ystep;
                        error = error - 1;
An integer divided by an integer performs integer division, whereas here you need to use floating point division:
float deltaerr = (float)deltay / (float)deltax;
However, the appeal of Bresenham's line algorithm is that it works fine purely with integers. Read the Wikipedia article a little further and you'll find the standard implementation.
Ah, thank you. I saw the other implementation further down, but I wanted to get this version working first 😁 Also, now I know that I have to do that to get it to divide correctly.
So did that fix everything for you, or is it still buggy?
It fixed it 😁
_player1537 wrote:
It fixed it 😁
Awesome! How fast is the code in lines or pixels per second? Have you tried benchmarking it?
Nope, no idea how to either :/
Draw a million lines, time how long it takes 🙂
The non-optimised version won't draw lines correctly owing to limitations in the representation of floating-point numbers - the integer version does not have this problem.
As a test, you can write a program that adds 0.1 - a value that cannot be exactly represented by binary floating-point numbers - to a variable and display the results.
std::cout.precision(20);
for (float f = 0.f; f < 10.f; f += 0.1f) {
    std::cout << f << std::endl;
This is why you should never store currency in floating point variables. (Fixed-point representations are generally used, such as storing the hundredths of the main currency as an integer - storing cents instead of dollars, for example, and there's usually a decimal type specifically for this type of usage).
