Raylin wrote:
Actually... that means that ASRPG could be optimized even more! o.o
And don't forget that with fixed-point packing, you could fit 99.99 and 99.99 together in a single floating-point number.
Raylin wrote:
o.o Fixed point packing?
For example, say you have two numbers A and B. If you can guarantee that A and B are both always between 0.00 and 99.99, with no more than two decimal places (ie, they can be 84.39 but never 2.109 or 103.4), then you could pack, for example, 12.34 and 56.78 together like this:
12345678
The packing code is simple (in E6 and E2, "E" is the small-caps E), here I'm putting the packed value in C:
Code: AE6+BE2->C
The unpacking code isn't much worse (assume the packed value is in C):
Code: E{-}2(int(CE{-}4->A
E2fPart(CE{-}4->B
Ooh. That. Didn't know it was called that.
Well, it's just packing in general; the fact that you're trying to pack in floating-point numbers means you need to call if fixed-point packing. It's fixed-point because you're dictating the exact number of decimal places, as is necessary to make the system consistent (for example, I'm sure you can see the problems if A is 10.001 and B is 80.00 - when you unpack A will be 10.00 and B will be 90.00).
