With my example GUI, no. The first would be the GUI Large Window, second would be GUI Text, third, fourth, and fifth would be GUI Radio Buttons.
calcman wrote:
so you omit str and have numeric value for number strN
also is the string (ans) stored as a list?
Yes, and yes respectively! also is the string (ans) stored as a list?
i figured it out....
+1+0+00001+text
+1= check box
+0= radio
+00001= num. box
+text= text box
right?
+1+0+00001+text
+1= check box
+0= radio
+00001= num. box
+text= text box
right?
_player1537 wrote:
Can you post the code you got those numbers from?
^This. It depends on what items you pushed onto the GUI stack before you called the GUIMouse. It looks to me like you pushed a check box, a radio button, a 5-digit number box, and a text box. Code:
:sum(7,0,255
:sum(7,1,"f8888888f8","Calcman test"
:sum(7,7,2,10,"button
:sum(7,11,35,"check
:sum(7,8,65,10,1,8,"8888888888
:sum(7,5,32
:sum(7,12,2,17,1,1,10
:sum(7,9,24,2,45,15,""
:sum(12,47,32,1
:output(1,1,str1this i made by myself!
Edit by Tanner: Use code blocks for code.
Very nice. My only criticism is that radio buttons are pretty useless as single items, but since this is a test program to understand the DCS GUI API, that's hardly a valid criticism. đ
You use those to open and close the stack. You shouldn't do stuff on the GUI stack before opening it, and you should always close it when you're done.
why cant i use xlib drawing commands and then use the sum(12
mouse command without the xlib drawings erasing?
It's something to do with how it's all put together. If I remember correctly, the best way to handle it is to draw all the xlib stuff, store it as a picture, and push the fullscreen picture item on to the GUI stack before rendering the mouse.
^this, I do beleive that the GUI will wipe everything when rendered.
Not exactly. If the first GUI element you push is a GUIR Null, with the Transparency byte set to 255, it will draw over what was there. Not sure if it works perfectly in Basic because I remember Souvik having lots of trouble with it.
OOOHHH YEEAAHH, I forgot about that there was an option to not wipe it >.>
:xlib code
:storepicN
:sum(7,3,N
:sum(12,x,y,1 Register to Join the Conversation
» Goto page Previous 1, 2, 3 ... , 10, 11, 12 Next
Page 11 of 12
