no, no, I meant it would just be calc connected by I/O cables.... no soldering or anything involved x.x
Ah, I see. Well, a two-calculator network would work with a simple I/O bridge, although more than two would require some soldering. My two-calculator network only required soldering because I needed the Arduino as a network monitor.
qazz42 wrote:
ohhh, ok, so I wont need an Arduino?
*Arduino, and no, only if it becomes necessary to use an Arduino for the gCn (globalCALCnet, computer to calculator) bridge if the SilverLink proves infeasible. For a two-calculator network, a unit-to-unit cable will be more than sufficient. qazz42 wrote:
aoah, ok, that makes alot more sense now ;D
and I fixed the misspelling...
Thanks for that. and I fixed the misspelling...
So I sent over my initial testbed program from four years ago, with some new modifications, to three of my calculators, and none of them crashes, although I discovered that I forgot to make them idle after CALCnet2.2 is initialized now that it's no longer in Doors CS and Doors CS isn't doing the idling itself.
qazz42 wrote:
I wonder, will gCn be worked on? Or was that just like "internet explorer 1.3 beta" ?
You mean v0.2 alpha?
qazz42 wrote:
eh, fair enough, I think gCn is a bit out or reach for now
CALCnet FTW
Maybe not out of reach, but outside of fun and awe-inspiring tech demos, less useful in the long run. CALCnet FTW
qazz42 wrote:
cool, is CALCnet a program or app?
Oh, it definitely won't be an App; I would never make something (within reason, I guess) that couldn't be run from Doors CS.
CALCnet FTW
I actually think there's a interesting use for calc <-> internet.
alberthrocks wrote:
CALCnet FTW
Qazz, nothing for you to test yet.
*bump* Made some progress in debugging and modifying my existing testbed program to be a bit closer to correctness. One crash I got makes me think that it actually transmitted properly, but once I fixed the crash I couldn't replicate the behavior.
Edit: I also found these tidbits:
;This file contains some routines:
; + Cn2_Clear_Recbuf
; + Cn2_Clear_Sendbuf
; + Cn2_Setup
; + Cn2_Int_Start
; + Cn2_Setdown
;What is Implemented:
; rec frame
; Int exit on unmatched SID
; rec frame wrapper
; send frame wrapper
; byte-receive routine
; byte-send ; byte-get routine
; Collision detection
; Cn2_Int_SendByte_OuterLoop masking H/L check
; get and store SID
; doublecheck rrc c and rlc c opcode functions -> decided on sla and sra instead
; Doublecheck send defines H/L in header.asm
; Reset setbuffer status flag on successful send
; Set getbuffer status flag on successful receive
; check linestate for send xmitbyte start
; collide receive if receive buffer contains data
; ack read on send frame
; ack write on read frame
; send frame
Awww, really? Oh well, I can test later when there is something I can test, please tell me if any testing is needed
Will do. I just modified the program to do something different if a message is successfully received, so I'll see if the problem was that nothing was getting sent, or it actually was and it just wasn't getting displayed.
Edit: On the minus side, still no success on transmission. On the plus side, fixed an issue with my netalyzer software that makes it a bit more reliable.
qazz42 wrote:
hmm, what soldering would be required to connect more than one calc?
At minimum, cutting apart two or more I/O cables, stripping the leads, and connecting them all together again. At a less-minimum, using some CAT5 to extend the network 10 feet or so (you couldn't get further without some booster hardware). Nothing too electrically-challenging, or even requiring any components other than I/O cables and wire.
On a related note, I've been occasionally staring at CALCnet2.2 in the midst of all the posting and drama that has been going on, so I'm hoping to bring some solid news of progress today!
Page 3 of 4
