Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: tokenide.exe
Problem Signature 02: 0.10.0.0
Problem Signature 03: 4fc3dcce
Problem Signature 04: TokenIDE
Problem Signature 05: 0.10.0.0
Problem Signature 06: 4fc3dcce
Problem Signature 07: 105
Problem Signature 08: 21
Problem Signature 09: System.IO.FileNotFoundException
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: ff6d
Additional Information 2: ff6d566fdcc8eae03c255b90fdbd6138
Additional Information 3: e4f0
Additional Information 4: e4f08d888aa57f402371367d18b8a828
Huh, that's strange, it thinks the file isn't found... Are you sure the file exists? Is this another thumb-drive problem or something?
Yes, the file is located on the flash drive. I can open Tokens and then drag and drop, opens just fine.
If you move the file to your hdd and do open-with what does it do?
Problem signature:
Locale ID: 1033
Man, that doesn't make any sense--it's calling the same code whether you drag-and-drop or open with. Can you put it in the same folder as Tokens and try that?
Problem signature:
Locale ID: 1033
Are you sure you have the most recent version?
Last date modified was 10/7/12
O_o; that's today. I guess try downloading from the site.
ugh, sorry v.v I'm reading through the C# stuff and didn't pay attention to what I was doing. :/ Files were last modified 7/31/12
Hmm, OK, that is the most recent (assuming the .exe is actually 8/1). I'll try to reproduce it.
I've got a bug located in the sprite editor. For 5x5 grids, the bottom right box seems to disappear when you select it after a short while, making it look white. However, the hex code actually remains unchanged.
Also for 5x5 grids, clicking "Hex Resize" results in an OutOfBounds (Array?) crash.
Thanks for the awesome IDE, shaun. I've always wanted one of these.
I've uploaded a new version here and at ticalc. Here's a screenshot:
Download:
http://www.cemetech.net/programs/index.php?mode=file&id=515
Hi, I've just made a Grammer token file to use TokenIDE as a Grammer IDE. (Looks like AxeTokens.xml, but it's Grammertokens.xml).
You can download it on TI-Planet now:
http://ti-pla.net/a9812
Enjoy !
That's great! Thanks so much for this. Can I have your permission to include it with the main download (credited, of course)?
Of course, I am delighted!
Thank you for this wonderful software !
EDIT: oh sorry, I uploaded a version with a bug. I update.
The Ctrl + F (Find) function, is that something that is just part of a standard library, or is it something you've set up? I ask because I try to find something, and it tells me it can't be found, but I know it is in the file. Just wondering if there is a way that I can do a search for a term and it find all instances of whatever it is, regardless of if there is something before or after it?
That's strange, there's no reason it shouldn't work. What are you searching for?
