Thank you. It looks good
basicman wrote:
Sorry should have asked this the first time.
Should I be prepared for my memory to be reset or anthing like that when I download this to my calc? Are there any precautions that I should be aware of before I download that are not posted?
Please do be aware that double posting is usually frowned upon unless there is a 24 hour time difference between posts, until the timp has lapsed, use edit.
No, not at all, although it's always very important to periodically group projects in progress and/or back them up to a computer. And as JosJuice said, Doors CS will detect all your programs for you.
Two points of netiquette:
1) Do not double-post; please edit your posts instead.
2) This is not the correct topic for this. Doors CS 7.1 Released or something similar would be better. This topic is about the Doors CS SDK.
Thank you, please let me know any further feedback you have on Doors CS (in the correct thread). Qazz, well, yeah.
Im on mac, so it would be compile.sh. I need to use the mac command prompt. What I'm asking is, what do I do after compiling? How do I make a .8xk, not .8xp? And how do I sign?
Brass allows you to do this provided that you have wabbitsign or wappsign, at least one of which will hopefully work via mono. I'd try wabbitsign before wappsign, personally. If you'd like, I can share my modified script for assembling applications, although you'd have to rewrite it slightly to fit the DCS SDK directory structure.
Whenever I compile a program (The source is in the source folder) it says it cannot open "binpac8x.py". Does anyone know how to fix this?
install python.
Both read the README and install Python.
Not sure if this is where this belongs, but clicking on the DCS_SDK link for DCS7, from anywhere, renders "Error retrieving data for specified file" and does not go to the download page. You may want to get on fixing this.
Which anywhere are you talking about? The Archives page appears to do exactly what it's supposed to:
http://www.cemetech.net/programs/index.php?mode=file&id=470
Edit: In addition, the Doors CS 7 SDK link on the Doors CS wiki, which leads to the Doors CS 7 SDK page on ticalc.org, also leads to a correct download:
http://www.ticalc.org/archives/files/fileinfo/341/34192.html
Edit #2: Apparently ACagliano is the only person to ever try to click the links on the Projects page for Doors CS 7. That SDK download link has been fixed.
» Goto page Previous 1, 2, 3
Page 3 of 3
