I figured out what's wrong with that weird area, I ran into the SAME problem when making WorldStage. In the terrain editor, go to action, and select "Clear Empty". Adjust your brush to the biggest, baddest shape possible, and click over all those weird areas in the water. Then, go to your world editor and shift the water block. Those weird areas should just disappear.
You need to make sure that you don't package the subfolder "Australia" in the ZIP file. Look at the default mod files to see how it should be done.
Lucas W wrote:
Congrats, I look forward to giving it a try! Feel free to submit the zip to the archives here, as well, once you make the change that CyberPrime suggested. Lucas W wrote:
Doesn't matter, as the mod manager doesn't want to launch my map, even if it's like that.
You also need to make sure all the fields are properly handled.
Lucas W wrote:
Are you asking him which fields he means exactly? Or asking some other question? Come on, more details, elfprince13 is no mind reader.
A heightmap shouldn't have anything to do with it.
If you browse the contents of the zip file, without unzipping, what do does the top level directory look like? Also, can you post the contents of your modinfo, and the actual name of your zip file.
Australia.zip>
Data
Editor
init.cs
Modinfo.txt
Modinfo.txt:
AUTHOR: Lucas
VERSION: Beta
DEPENDENCIES: TerrainFixer;
DESCRIPTION: A map by Lucas
Data
Editor
init.cs
Modinfo.txt
Modinfo.txt:
AUTHOR: Lucas
VERSION: Beta
As long as those are tabs between the "NAME:" and the actual name, yea, that looks great. Submit it and I'll make sure it's all good. Then you can submit it to the archives and whatnot.
Well, yes, there are tabs but that's not the problem.
The problem is that when I try to load the map TBG gives an error that it can't find the needed files.
Also, when flying upward, the ground goes all black.
And I have already posted a link with the files.
Alright; two problems. First problem is that you have all the files in a folder called Australia, which is then zipped. Your file looks like this:
when it should be
As well, remove everything from init.cs since your not actually executing anything
And thirdly, your main problem with the map seems to be with registering the terrain block.
Australia.ZIP
- Australia
> Data
> Editor
> Init.cs
> Modinfo.txt
when it should be
Australia.ZIP
- Data
- Editor
- Init.cs
- Modinfo.txt
mods/Australia/data/missions/TBG-Australia.mis (0): Register object failed for object Terrain of class TerrainBlock.
Page 2 of 4
