So I managed to get my /projects/wt folder suspended, as per this email:
This has convinced me it's time (or getting towards time, anyway) to overhaul the way that WorldTrends works. Instead of storing all minute-by-minute data from a variety of sources and per-five-minutes headline data, I believe it would be better to record statistics from a larger variety of sources at a larger interval, perhaps once per hour, then compressing said data once per day for day one week previously. This will reduce by about 10,000-fold the data quantity (and processing) needed to generate the graphs and other data WT2 works with. Also, the larger variety of sources should allow for more accurate tracking of trends across several fields. I will be alerting my hosting provider to this so I can get that support thread closed.
CGI/PHP Overload
This account is responsible for extremely high resource usage, which generates excessive load on the server:
aheamizw cemetech.net 29.26 61.36 2.2
Top Process %CPU 99.6 /usr/bin/php index.php
Top Process %CPU 97.5 /usr/bin/php index.php
Top Process %CPU 96.6 /usr/bin/php index.php
This means your account was responsible for 29% of the CPU usage and 61% of the server's RAM usage on a daily scale.
