Hello all!
I just got my TI84+ two days again, and I'm realy enjoying finding things to add to it. I stumbled on DOORSCS6 yesterday, and I simply love it!
But now, I have a small question; how do I put in text files (I'd prefer to type those on the computer) and other files on it? I think this is possible since I saw it on a screenshot posted at calg.org .
Thanks in advance,
Kirth.
http://www.cemetech.net/projects/docde6/
That should be what you are looking for.
Cool! A very usefull system!
Thank you very much!
One more question, would it be possible to make a shortcut to other applications or prgms? And also would it be possible to put images on your calc. (to put them like on the calc).
What do you mean make a shortcut? If there is a program on your calc that isn't listed in DCS, that means it isn't compatible with DCS (as in DCS can't run it)
As for the images on calc, you can, but just remember you will have to use a tool to convert it (can't remember the name of one), and it will only be in 4-level grayscale with a resolution of 96x64 - in other words it will look horrible.
EDIT: Why did you edit your post to make it two posts? Double posts are a HUGE no-no - don't ever do that again. You must wait at least 36-48 hours before it is acceptable to double post.
Euhm yes I know.
Sorry, I didn't see an edit button at first <,<.
(I'm browsing in a small screen, since I'm watching naruto ^_^)
Thank you for your responce!
Kirth wrote:
Euhm yes I know.
That wouldn't explain why you took a single post
And then edited that post to SPLIT it into two posts.
Could we get back on topic please?
EDIT: Another question; is it possible to make files invisible?
Since I downloaded the 'Lightning' game, but it requires another file to be on my calc. (INVERT.8xp) which just brings me back to Doors when I try to use it. The question is if I can hide this?
Invisible files: edit the program to have the token Ans as the first line of the program.
Shortcuts: could you elaborate?
No!! That would be my game and Invert is an asm program so do not edit it. IT inverts text and turns off the run indicator so leave it the way it is.
No!! That would be my game and Invert is an asm program so do not edit it. IT inverts text and turns off the run indicator so leave it the way it is. So why didn't you put a .db $AB at the beginning of the ASM program to hide it from DCS?
I didn't make it, It was before I knew asm so ask Harrier why he didn't put it there.
Yeah, but you could fix it now that you know ASM...
OK I'll ask him for the source because I don't know enough asm yet to remake it by myself.
Didn't I write INVERT for you during school one day (FDCB05DEC9)?
Harrier made me better one that will turn runidicator off every time it is ran and the cheak ans and if it =/0 the it inverts text but if Ans=0 the it uninverts text.
Ah, I see. I suppose that's so you can un-invert the text before you exit? If so, this would be easier:
ld a,(iy+5)
xor %1000
ld (iy+5),a
ret
It'll just set inverse text if it's normal, and back to normal if it's inverse.
EDIT: I missed the part about the run indicator, but resetting bit something, iy+whatever works for that
