I've been trying to create an array of strings in Java. Here's my code (only the parts giving me problems):
In Class A:
Code: public class A{
private String a[10];
public void changeElement(String e, int num){
a[num]=e;
Here's my application code:
Code: import Java.util.Scanner;
public class App{
Scanner reader=new Scanner(System.in);
System.out.print("Elements(less than 10):");
int j=reader.nextInt();
A test=new A();
for(int i=0; i<j; i++){
While(reader.nextLine()=="\n");
System.out.print("\nInput element "+i+":");
A.changeElement(reader.nextLine(),i);
What's wrong with this? It compiles fine, but throws a runtime error pointing to changeElement when I when I try to run this code and it reaches that point.
My guess is because you are saying A.changeElement() instead of test.changeElement()
But why are you encapsulating a string array in a class anyway? Tad bit of overkill...
not sure on the error, but have you tried eclipse out for development?
In Class A:
a[num]=e;
public class App{
A test=new A();
what IS the runtime error?
Do you really even need to know that? Look at this line. I don't even know Java and I see a glaring problem with it
Code: A.changeElement(reader.nextLine(),i);
Java would be pretty stupid if you created a variable called test (of class A) and then accessed it using A, instead of by its name (test)
...which is, of course, what I said in my first post. Or did you miss that?
oops, that's a typo on my part. the code really was supposed to be
test.ChangeElement.
I found out the reason why I was getting an error:
to get an array of strings, you need to do
Code: private String[] a = new String[10];
instead of
Code: private String a[10];
indeed, although its still helpful to provide the runtime error when you want help debugging it.
here's the error:
output wrote:
exception in thread "main" java.lang.NullPointerException
A line number would be incredibly helpful here...
do people listen? Eclipse will tell you where the error is, and ideas on how to fix it.
Indeed, that's what I started using for my IDE. It doesn't do it for runtime errors, though.
