looks nice
I dont see the big map when i view this page. I just see a gray square saying "applet loaded" and the minimap to the right, nothing else happens
I know I am not doing anything wrong because i have java installed and it's the lastest version as well (downloaded last week), and I was logged in. I use Opera btw
EDIT: I've tried again, waited one minute, and still nothing appeared. I am on a 7.5 mbps connection btw
EDIT: 2 minutes now, and still nothing
I get a message (in the status bar of FF) saying that the Applet failed to load, or a message saying 'Applet multiplicity notloaded' exactly like that. =X
Go to Tools-->Java Console and paste the contents here.
Sorry to report, but I have no Java Console, just JavaScript Console. I went to help and searched, Preferences. I'll try on another browser. Update when I get results.
If not, go to the bottom-right of your screen, right-click on the Java icon, and choose the console.
oookay: I loaded Multiplicity in Safari, didn't load (yes I logged in), I went to the java console, and this is what I got.
Nothing. (code thing just for a laugh or two)
As for the bottom right corner... nothing there either.
I'll hop on my sisters windows and give it a try. Maybe its not cut out for a Mac... or maybe I should install FF 2.0, after all, I've downloaded it about 3-4 months ago or something along there...
Kerm, they cant use it unless they have J3d installed, and unless they have a Java version at least as high as what you targeted.
download j3d 1.4, and compile your applet with the -source 1.4 -target 1.4 switches.
That's what I suspect as well, but I need to verify it. download j3d 1.4, and compile your applet with the -source 1.4 -target 1.4 switches.
That's what I suspect as well, but I need to verify it.download j3d 1.4, and compile your applet with the -source 1.4 -target 1.4 switches.
its correct, I verified it this morning.
it will not load for me either and i have the latest java installed. here is what my console says:
Java Plug-in 1.5.0_04
Using JRE version 1.5.0_04 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\Justin
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
java.lang.NoClassDefFoundError: javax/media/j3d/Bounds
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.plugin.AppletViewer.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
g: garbage collect
o: trigger logging
q: hide console
t: dump thread list
1.6.0 is actually the latest, and yes, that means j3d doesn't exist on your system. I'll have to do what Elfy suggested.
Things as low as FF 0.9 have a Java Console.
Anyway, hope this can get resolved somehow.
And things as high as ff 2.0 have had Java (and JavaScript) consoles REMOVED
That, and the Java Console isn't built into firefox anyway, and the icon is only there if you tell it to be in the Java control panel (in windows, enabled by default. I disable it because its so freaking annoying)
Can't you just right-click the applet and get it that way, though?
Page 3 of 5
