I understand that that's the 32 bit integer limit but I'm making a cookie clicker port, and it's difficult to make a proper clicker when it clocks out at about 4 billion, especially since the first major milestone (ascending) takes 1 trillion cookies. How would I go about making larger integers? Is there a library I can use that adds a new variable type that can go above 2^32-1, and if so how would I implement it? I can't imagine people spending too much time on TI-84 CE cookie clicker lol, so nothing too wild but maybe 2^64 would be good, 2^128 would be perfect but reaaallly stretching it I'd assume. Any help is appreciated!
Can I use a function to render that to the screen (like gfx_PrintUInt) or does that only work with int and unsigned int?
This is absolutely a necro-post, but I think I have some insight which may help you with your latest project. For an incremental game like cookie clicker, it's best to not actually use such large numbers but instead to use something like a float.
The key observation here is that when the player is making trillions of cookies every second, they don't care about single-digit numbers of cookies. Instead, think about their cookie count in something like scientific notation. You store a few significant digits (here called the mantissa) and an exponent of some fixed base. This allows you to scale much, much farther than if you cared about every single cookie, and operations on this number are more or less the same speed regardless of whether the user has 200 cookies or 10^200 cookies. You can read up more on floating point numbers here.
I’ve had good experiences with this library: https://github.com/kokke/tiny-bignum-c
