A few days ago I got a SR-10 from a friend at my local makerspace. This particular model is a SR-10 Version 2 hardware revision D. I'm not sure where the date code is but this model was first released in 1973.
It hadn't been used in 40+ years and had very exploded batteries. I made the very difficult choice to void my 50 year old expired warranty and fix it up. Thankfully the explosion was almost completely contained in the battery compartment so the cleanup wasn't too difficult. When I put in new batteries it turned on and all the buttons work and feel great! The calculator comes with built-in power saving mode which looks so cool when it activates! https://i.imgur.com/OtfsXkX.mp4
My 50 year old warranty
It's not perfect though. The display has some issues I need help diagnosing.
Thankfully DataMath.org has documentation on not only the display, but the four display drivers.
'Calculator on Chip': http://www.datamath.org/Chips/TMS0120.htm
Display: http://www.datamath.org/Displays/DIS115F.htm
Top 2 display drivers: http://www.datamath.org/Chips/SN75494.htm
Bottom 2 display drivers: http://www.datamath.org/Chips/SN75493.htm
DataMath states: "The two SN75493 Segment Drivers for four segments, each and the two SN75494 Digit Drivers for six digits..."
Datamath insides vs my calc's insides:
(click for full size)
So if I understand this right:
Is my understanding correct? What do you guys think could be the issue?
I would really appreciate any guidance!
- The far right digit (used to represent the first digit of scientific notation) only displays a single dot at the top instead of a number (see left pic below).
- The second from left digit always mimics the number shown on the fourth digit from the right (see right pic below). If I fill up the screen with numbers, the second from left digit still displays the correct number, it just overlays the correct number with the number it's mimicking.
- Each of the SN75494 drivers handles 6 of the 12 digits on the display. It handles storing which number goes in which position?
- Each of the SN75493 handles 4 of the 8 segments on each digit.
- For the first issue I suspect the whole digit is broken? Since none of the other digits are like this, I don't think it's a driver issue. Is it safe to apply power to the individual segments myself to test them?
- For the second issue, my thought is either one of the SN75494 drivers is broken, or one of the components between the driver and the display is broken. I'm not sure what component could break that could cause this issue though.
