When I try to print a value over the uint24_t max value, the function overflows and displays back up again from zero. Is there a way to fix this?
That is a property with computers in general. See the Wikipedia article on it.
You could use sprintf to print the larger number to a string, then use gfx_PrintString instead.
For example, if you want to print a uint64_t:
#include <inttypes.h>
#include <stdio.h>
void printUInt64(uint64_t num) {
char str[21]; // 64-bit numbers have at most 20 decimal digits
sprintf(str, "%" PRIu64, num);
gfx_PrintString(str);
Now getting error:
EDIT: FIXED, HAD TO PASS POINTERS
Double post combined into one post by admin
Got it working, thanks Calc84Maniac! Have a nice day everyone!
1 warning generated.
[lto opt] obj\lto.bc
fatal error: error in backend: Error while trying to spill UDE from class O24: Cannot scavenge register without an
emergency spill slot!
PLEASE submit a bug report to https://github.com/llvm/llvm-project/issues/ and include the crash backtrace, preprocessed source, and associated run script.
Stack dump:
0. Program arguments: D:\\logan\\Documents\\CEdev\\bin\\ez80-clang.exe -S -mllvm -profile-guided-section-prefix=false -Wall -Wextra -Oz D:/logan/Documents/CEdev/CalcClicker/obj/lto.bc -o D:/logan/Documents/CEdev/CalcClicker/obj/lto.src
1. Code generation
2. Running pass 'Function Pass Manager' on module 'D:/logan/Documents/CEdev/CalcClicker/obj/lto.bc'.
3. Running pass 'Prologue/Epilogue Insertion & Frame Finalization' on function '@Draw'
0x765490E2 (0xE0000046 0x00000000 0x00000000 0x00000000), RaiseException() + 0x62 bytes(s)
0x005F1BA6 (0x00000100 0x00000000 0x00000020 0x00000013)
0x01000000 (0x00000000 0x00000020 0x00000013 0x0000000A)
ez80-clang: error: clang frontend command failed with exit code 70 (use -v to see invocation)
clang version 15.0.0 (https://github.com/jacobly0/llvm-project 5f8512f22751066573aa48ac848a6d2195838ac3)
Target: ez80
Thread model: posix
InstalledDir: D:\logan\Documents\CEdev\bin
ez80-clang: note: diagnostic msg: Error generating preprocessed source(s) - no preprocessable inputs.
make: *** [obj/lto.src] Error 1EDIT: FIXED, HAD TO PASS POINTERS
