I created a #define called MAX_DATA_SIZE in an include file here: https://github.com/randomguy70/smartNotesRewrite/blob/d15753a303f54bb75c7a456550bbf29978bbeb6a/src/file.h#L23C14-L23C14
and I tried to use MAX_DATA_SIZE in another include file here when creating a struct: https://github.com/randomguy70/smartNotesRewrite/blob/d15753a303f54bb75c7a456550bbf29978bbeb6a/src/editor.h#L41
and I always get an error saying that MAX_DATA_SIZE is an undeclared identifier, although I know the compiler recognizes it as defined because it ran this code.
#ifdef MAX_DATA_SIZE
#warning it's defined
#endif
Thank you in advance!
I have no immediate answer to your problem, but a useful technique to debug preprocessor issues like this is to have the compiler stop after running the preprocessor by passing -E. I see from your repository that you're building with a Makefile so you can find the invocation of ez80-clang that your problematic .c file is being built with, then add -E to make it emit the preprocessed output so you can see what definitions are being inserted (and I believe where they come from).
#endif
Did you insert this code near your struct definition, or near where MAX_DATA_SIZE is defined? I see you have some other header definitions between including file.h and declaring that struct: do those other headers #undef MAX_DATA_SIZE?
You are including editor.h inside of file.h before MAX_DATA_SIZE is defined.
As a general rule, header files should be written to not depend on other header files (besides system/library ones)
#endif
I put that code right before the struct definition.
Should I just substitute the integer value 3000 for MAX_DATA_SIZE in editor.h? I thought it was good to use #defines to organize &/ keep track of magic numbers.
Edit: I moved the
#include "editor.h"
that was originally in file.h into file.c. (Not exactly sure what I was thinking before).
No, you should write your code better.
This may not be related to your issue, but why do you have this line before the declaration of the structure?
Because he's one of those heathens that uses global variables
I am indeed a heathen who uses global variables. In this case, I was messing around with the order of struct declarations to see how the compiler would respond. 😛
