I have been experimenting with the graphical capabilities of the HP Prime in its BASIC language. I thought of this idea when I had a HP Prime G1 and it just didn't work, but the HP Prime G2 allows it to work.
It uses any spare (G1-G9) graphic screen GROB as a buffer of a Large (png) file, and then accesses it as it has to.
You can get short bursts of video playback, or longer scrolls of a wide image! (The SMB Level one is 3900px wide and the DOOM level is 30000px wide).
Here is a program to have a go at playing back a video on the HP Prime G2 for yourself:
EXPORT dvidW()
BEGIN
DIMGROB_P(G4,30000,240);
    LOCAL H,EXIT;
  H:=0;
  G4:=AFiles("WeeZ.png");
REPEAT
  BLIT_P(G0,0,0,320,240,G4,0+H,0,320+H,240);
 H:=H+320;
 IF H>29670 THEN H:=0;END;
 WAIT(0.04);
 IF ISKEYDOWN(4) THEN EXIT:=1; END;
UNTIL EXIT=1 ;
END;
And here is a formatted file that will allow a video to play: https://bit.ly/3Dbg7Uj - This file must be put into the Application Library 'Files' for the particular application you are running, otherwise it will give an error "Invalid Input". Only works on HP Prime G2.
At 25 FPS playback, it works out to be 3.72 seconds, displaying 93 frames. Remember it is running in HP PPL!
The video has to be short, but I didn't see any other video players for the HP Prime yet, did I miss any?
This is very impressive! I'm stunned how smooth it looks! I'm not sure if you want more fps , but if you write this same program in Python it might have even batter results since there's no speed limitation to Python programs.
I'm not aware of any other video playback programs so yours might be the first. Good job!
I am especially amazed by the video playback. To work on G1 hardware you would need to split all frames into separate images and load them one by one. I did try parralax mapping before and got good results but it was only 960x240 or something like that.
By the way, what did you use to convert the video file into individual images or a sequence of images?
Something I noticed when experimenting with converted videos is that past a certain ICON width I get a syntax error while I could use 65500 pixels of height. The max resolution I got is 80x60 at 4-ish FPS (I had to use a WAIT command to slow it down to 4 FPS, else it played too fast). 10.9 MB of video data that obviously won't fly well with a G1 revision model.
EDIT:
