Is it possible to retrieve the CAS product ID from a program? As far as I know, there is no in built command to do this, and the only way I can find is by using a lua script running the command platform.getDeviceID(). My idea is to somehow integrate a lua script into a TI program, which I'm not to sure if a method exists? If so, the program could call the lua script to change/define a variable with the product ID and display this. Any ideas?
