- Black loading screen on ti84 plus
- 11 Mar 2025 11:21:04 pm
- Last edited by dryforest on 12 Mar 2025 12:07:59 am; edited 1 time in total
I don't know much about calculator programming, forgive me if I explain this poorly!
Whenever I run this program (Anyform, chemistry program where you input a reaction to get some tidbits and the balanced equation, got it off ticalc.org), a lovely black loading screen sweeps the screen from left to right, but at the end when the results of the program show, the black bits stay, only avoiding a couple of the outputs. My issue is that the loading screen seems to be covering or somehow hindering some of the functionality. For whatever reason it doesn't cover the other bits, but the equation that is supposed to pop up on the bottom of the screen is missing. Any ideas? Maybe it's the zoom, I'm not sure .
UPDATE: fiddled with the settings some more, the issue was that I had selected the grid option under "Format". Unfortunately the issue persists, no chemical equation appears. It appears to work beautifully in the example so I'm sort of at a loss.
