I have taken apart my TI-Keyboard from circa 2002, and have made a little Imgur album:
https://imgur.com/gallery/uhEAOtt
The case and PCB are significantly different that the other teardown that exists, even though they share the same part number.
https://imgur.com/a/llMQU7n
Notably, on my keyboard, there are no longer provisions for the second link port within the case mold, but there are still unpopulated pieces for a second port on the PCB. The serial number format is different as well. The PCB sports the work Silitek on the silkscreen, a division of Lite-On according to the Deskthority Wiki https://deskthority.net/wiki/Silitek. The main chip on the PCB seems to be a very similar part, EM78P451A0 vs EM78p451SA0S. This seems to be a low-power one-time-programmable general 8-bit microprocessor. http://www.datasheet-pdf.com/PDF/EM78P451-Datasheet-ELANMicroelectronics-546102
I have also mapped out the matrix of the keys formed by the membrane, with the plan to replace the membrane with a PCB to support mechanical key switches.
