- Potentially Broken Computer
- 17 Nov 2021 10:16:36 pm
- Last edited by epsilon5 on 20 Nov 2021 11:57:27 pm; edited 1 time in total
Hey Cemetech-I'm not sure if this is an appropriate thing to ask on the forums, but I've had a very large computer issue earlier today, and am unsure of how to proceed. I'm not here for tech support, as there are better places to do that-simply asking if anyone has ever encountered a similar issue and if it was solvable. I've also created a topic (that this is mostly copied from) on the HP Support Forums, but given that there are no replies yet, and that the majority of topics don't seem to receive any, I'm not counting on a response there.
System Specifications
HP Pavilion 16t-a000
i7-10750h
GTX 1660ti Max-Q
2 x 8 GB G.Skill Ripjaws DDR4 RAM (aftermarket)
500 GB Western Digital Black SN750 SSD (aftermarket)
1 TB HDD
Problem
When attempting to boot, the computer either gives a black screen or what appears to be memory corruption (possibly of VRAM, randomly colored pixels throughout the screen). Occasionally, I'll be able to get it to boot to Manjaro KDE (my OS), around 1 time in 30 or 40. However, when using the operating system, the problem will return, with the screen becoming corrupted/shifted and all input freezing. The BIOS is inaccessible most of the time, with the screen becoming corrupted or the Caps Lock key flashing before it can be accessed as explained below.
Diagnosis
The Caps Lock key gives three long followed by two short blinks, which according to this article suggests that "the embedded controller times out waiting for BIOS to return from memory initialization," or possibly a general system board failure.
Attempted Solutions
As my computer does not have a removable battery, I followed the suggested protocol (by the HP Virtual Agent) of disconnecting the AC adapter and all connected peripherals, holding the power button for 15 seconds, and then reconnecting the AC adapter and powering back on. I also took the computer apart, removing each of my 2 RAM sticks one at a time, as well as testing with an extra 4 GB RAM stick that the computer originally came shipped with. Using the HP Hardware Diagnostics UEFI, I ran processor, memory, and system board tests, all of which passed. None of these solutions appeared to help.
EDIT: Also tried holding the power button for 30, 60, and 120 seconds, and holding both Super+B and Super+V at boot, but none of these solutions worked either.
Here's a general idea of what happens, captured from within the BIOS (the issue appears to be universal-it's happened within the OS as well). This is very rare, however: I usually can't even get into the BIOS or the OS at all. The colored lines and pixels do change in pattern, which would be kind of cool to watch if it wasn't my computer.
Conclusion/Warranty Information
This product is out of warranty (I purchased it in August 2020 for around $900 to my recollection, not including the extra hardware I got for it), which appears to mean that it is no longer eligible for official HP support. With that said, if that matters at all, I've always been careful with it, keeping it in a case when I go to school, and I've never dropped it. Is there anything that I can do to fix it, or do I have to buy a new computer? Thanks for all of your help in advance (again, just looking for very general tips if you have any). And mods-please remove the topic or give me a warning if this isn't something that should be posted on Cemetech.
i7-10750h
GTX 1660ti Max-Q
1 TB HDD
Problem
Diagnosis
Attempted Solutions
