Could anyone explain how to use a YAML file when converting images with Convimg? I followed the instructions in the ICE documentation, but they were written for ConvPng. What are the differences between Convimg and Convpng, and how exactly do you convert images with Convimg? Thank you! By the way, I'm using mac.
here is the YAML:
palettes:
- name: mypalette
images: automatic
converts:
- name: hi.png
palette: mypalette
images:
outputs:
- type: ice
include-file: ice.txt
palettes:
- mypalette
converts:
- myimages
palettes:
- name: mypalette
images: automatic
converts:
- name: hi.png
palette: mypalette
images:
outputs:
- type: ice
palettes:
- mypalette
converts:
- myimages
palettes:
- name: mypalette
images: automatic
converts:
- name: hi.png
palette: mypalette
images:
outputs:
- type: ice
palettes:
- mypalette
converts:
- myimages
randomguy wrote:
here is the YAML:
palettes:
- name: mypalette
images: automatic
converts:
- name: hi.png
palette: mypalette
images:
outputs:
- type: ice
palettes:
- mypalette
converts:
- myimages
palettes:
- name: mypalette
images: automatic
converts:
- name: hi.png
palette: mypalette
images:
outputs:
- type: ice
palettes:
- mypalette
converts:
- myimages
I think that I see what's wrong.
You say that it should convert 'myimages' but that's not the images it should convert, that's the name of the pallette.
palettes:
- name: mypalette
images: automatic
converts:
- name: images
palette: mypalette
images:
outputs:
- type: ice
palettes:
- mypalette
converts:
- images
That will do it probably.
This works:
You're trying to convert "myimages", which doesn't exist, you had "hi.png" which isn't used.
palettes:
- name: mypalette
images: automatic
converts:
- name: myimages
palette: mypalette
images:
outputs:
- type: ice
palettes:
- mypalette
converts:
- myimages
"You can say literally anything and claim it's a quote from The Art of War." -Sun Tzu Update your MyCalcs coward.
Terminal still says:
childrennointernet@MacBook-Air ~ % /Users/childrennointernet/Desktop/untitled\ folder/convimg ; exit;
[error] Missing input file.
[info] Run /Users/childrennointernet/Desktop/untitled folder/convimg --help for usage guidlines.
[info] Run /Users/childrennointernet/Desktop/untitled folder/convimg --new to create a template 'convimg.yaml' file.
[Process completed]
- Privacy_Dragon
- Advanced Member (Posts: 192)
- 16 Jan 2021 01:58:29 pm
- Last edited by Privacy_Dragon on 16 Jan 2021 01:59:25 pm; edited 1 time in total
[Process completed]
ah, you should do:
/Users/childrennointernet/Desktop/untitled\ folder/convimg i convimg.yaml
so first call the convimg, then say i, followed by the yaml file.
commandblockguy
- Minor Calculator Deity (Posts: 1133)
- 16 Jan 2021 02:01:11 pm
- Last edited by commandblockguy on 16 Jan 2021 02:10:19 pm; edited 1 time in total
You need to either run convimg in the same directory that contains the convimg.yaml file, or call convimg with convimg -i /path/to/your/convimg.yaml
I'd also recommend renaming "untitled folder" to something else, as spaces in directory names cause tons of issues for command-line tools.
then do:
where you replace $(LOCATION_OF_CEDEV_FOLDER) for the location of the CEdev folder.
and replace $(FOLDER_WHERE_YAML_FILE_IS_LOCATED) for the location of the folder where you have the convimg.yaml file.
And as commandblockguy says, the space might indeed be an issue, maybe replace the space for an underscore
./$(LOCATION_OF_CEDEV_FOLDER)/bin/convimg i $(FOLDER_WHERE_YAML_FILE_IS_LOCATED)/convimg.yaml
It works now, except that it has an issue on "mapping values"
[info] Reading file 'convimg.yaml'
[error] Problem description: mapping values are not allowed in this context
[error] Problem is probably around line 2.
[Process completed]
palettes:
- name: mypalette : Palette and name of palette
images: automatic : Automatically get list of images
converts:
- name: myimages : Convert images section
palette: mypalette : Use the above generated palette
images: : List of input images
outputs: : List of outputs
- type: ice : Sets the output format to ice
include-file: ice.txt : File name containing all images/palettes
palettes: : Start of palettes list in the output
- mypalette : Name of each palette, separated by line
converts: : Converted sections, based on name
- myimages
this is my actual yaml
palettes:
- name: mypalette
images: automatic
converts:
- name: myimages
palette: mypalette
images:
outputs:
- type: ice
palettes:
- mypalette
converts:
- myimages
but terminal still says:
childrennointernet@MacBook-Air ~ % /Users/childrennointernet/Desktop/JohnPaul\'s\ Folder/TI\ 84\ Plus\ CE/Project\ Files/ConvImg/convimg ; exit;
[Process completed]
how? I thought i followed the instructions, i even copied and pasted the code from your Oiram example.
I ran convimg.exe using the following .yaml
and ice.txt was outputted successfully, so there definitely isn't any issues with convimg itself. I wonder if there might be a bug specific to MacOS (since I'm on windows?), but I'm not going to jump to any conclusions.
Anyways, if you want convpng specifically, then you can just go through convimg's release history on github and grab the latest version of convpng before it was directly replaced by convimg here. Then just move convpng.exe into the same directory as your .ini file (as described in the ICE documentation), and then you should just be able to run convpng.
Just a hunch, but you may want to check that hi.png is truly formatted as a .png (as in, its not a .jpg with a .png tacked to the end of it)
Also, as a note, if you want to add something to your post and no one has responded to it, its generally good practice to simply edit your last post instead of posting multiple times consecutively.
palettes:
- name: mypalette
images: automatic
converts:
- name: myimages
palette: mypalette
images:
outputs:
- type: ice
palettes:
- mypalette
converts:
- myimages
He's just running from the wrong directory. There's a convimg.yaml in his home directory that he keeps trying to convert.
i already switched the directory with "cd" in the terminal to the folder in which I have the .png, yaml, and convimg:
however, there is still the error. am I supposed to put all the stuff in my home directory and just run it from there, or can I keep it in the folder it is in? and, was I supposed to switch directories in the terminal a different way? and, did I use cd correctly?
childrennointernet@MacBook-Air ~ % cd /Users/childrennointernet/Convimg
childrennointernet@MacBook-Air Convimg % /Users/childrennointernet/Convimg/convimg2 -i /Users/childrennointernet/Convimg/convimg.yaml
[info] Reading file '/Users/childrennointernet/Convimg/convimg.yaml'
» Goto page 1, 2, 3 Next
Page 1 of 3
