I think I will just make 1 topic for all of my many questions for ICE. Right now I am wondering why one of my programs can't delete the correct appvar with its name stored in Str2. Instead, the program deletes the wrong AppVars.
Code: 0->POS
While (Detect(^^oPOS,"TXT"->CURNAME and (NUMBER<10)
getKey->K
CloseAll
//get file info
Open(CURNAME,"r"->CURFILE
GetSize(CURFILE->SIZE
SetArchiveStatus(1,CURFILE
''->Str1
sum(31,Str1,CURFILE
//display file info
If SELECTED=NUMBER
SetColor(0
FillRectangle_NoClip(35,Y-5,250,15
SetTextFGColor(246
Else
SetTextFGColor(0
//DISPLAY DETECTED FILES
PrintStringXY(Str1,40,Y
SetTextXY(135,Y
PrintInt(SIZE,4
////BUTTON FUNCTIONS
//DELETE
If K=51
Delete(Str1
Goto HOME
NUMBER+1->NUMBER
Y+15->Y
Thank you in advance!
SAX wrote:
<commandblockguy> you probably want to add a check to see if Str1 is the one that's actually selected
<commandblockguy> e.g. If K=51 and SELECTED=NUMBER
<commandblockguy> that way only the selected one will get deleted, not the first file found after the user pressed key 51
<randomguy> thank you, commandblockguy! it worked!
<randomguy> that makes sense now!
Is it possible to delete a string in ICE or at least to delete all the characters from a string? I tried '->Str1 and "->Str1 and ''->Str1 and ""->Str1 but those didn't seem to work. thank you in advance!
Edit: 0->*{Str1} works
how would you start the pos at an offset when detecting files in a shell-like menu as seen above, in order to scroll? I know that the pos is a pointer, not a simple 1,2,3 count, so how would you start searching for files starting after a certain number (ex. searching the files starting from the third file in the vat). As you can see, my program stops displaying the files after the 10th so as to avoid running them off the screen, but when I deleted some files, it updated the detected file names. So all I need is a way to be able to scroll down the file names.
0->NUMBER
0->POS
Open(CURNAME,"r"->FILE
NUMBER+1->NUMBER
Also, How does P_T converted the memory mapped addresses in the pointer section of Ice documentation to hexadecimal?
Here is the section in which he did it:
Here is a page with ports for the real-time clock in the 84+ CE. Near the top of the page it says Memory-mapped address: F30000, this means that you can read from these ports as if they were memory by using the F30000 address range. Below you find a list of specific ports. If you wanted to read the current hour count, that page lists it as port 8008. You simply modify the memory mapped address to get F30008. Before you can use this in a pointer, you need to convert it from hexadecimal. Luckily, ICE has a modifier just for that, the scientific E. With this, you should now be able to read the current hour and store it into, for example, A, like this:
{|EF30008→A}
Now you can use that hour however you wish to in your program.
I have an Ice program which works fine except sometimes it freezes and then glitches when I try to exit (with 'clear'). The screen breaks into 4 mini versions of itself, and glitches painfully! However, after I press clear again, the program exits and everything is normal. Otherwise the program is mostly fine. I had this problem with my other Ice program but I forgot what I did to get around it.
Does anybody else have/had this problem and/or know how to fix it?
Glitch image:
Glitch recording:
Ps. The program looks like it is pale green, but it is actually gray on-calc.
I don't know much about ICE, but based off the symptoms it's possibly a stack issue where the program tries to quit (and so switches the screen back to 16-bit mode), but still has 1 or more un-popped entries on the stack.
Maybe you're doing a Goto out of an If/Then/End or something like that? Doing that is a big no-no, even in raw Basic it causes memory leaks.
yup, that is exactly what I am doing. it is in the middle of 2 nested if statements!
how would I exit if i can't say
If getKey(51
goto X
If statements do not use the stack in ICE.
I'm rusty on Basic, but if I recall correctly, then you don't need the "End" on your example above as there is only one command after the "If". So I
think the following would work without a potential memory leak:
If getKey(51
Goto X
Lbl X
Isn't ICE Basic with extra commands, like Axe? If so, then If/Then/End blocks will still use the stack behind the scenes.
I'm not 100% sure, but worth a try anyway
Sorry my bad, I forgot ICE is a compiler and not parsed like Axe was.
Could be an ICE bug as Mateo suggested in chat..
Um Axe is a compiler too
Big lol, woops
Sorry randomguy, I might have given you the run around for nothing!
Although regardless, having Goto inside an If/Then/Else/End is still a bad habit to get into. Unfortunately, TI left a gaping trap for us with their Basic language.
okay, so SourceCoder 3 was compiling fine until a couple days ago. Now, whenever I press the compile button, it just says Javascript:void(0). why is that, and how can I fix that?
Edit: There was a syntax error (I had an extraneous '/'), but SourceCoder 3's built in compiler didn't show it. I had to click on 'check' to see what was wrong.
By the way, is it true that all prime numbers are either 1 or 5 above a multiple of 6 (besides 2 and 3 and 5)?
