Is there any way to run an assembly program from an ice program (shell)? I know you can run a basic program from Ice, but I can't find how to run an ASM program. Thanks in advance!
epsilon5
- Super-Expert (Posts: 833)
- 21 Feb 2021 08:48:20 am
- Last edited by epsilon5 on 21 Feb 2021 08:50:43 am; edited 2 times in total
I believe that this is the method that most of the ICE shells used to do it.
I don’t recommend making a shell in ICE though, as most of the ICE shells are very unstable and don’t work all that well, because of the language’s difficulty in interfacing with the OS. Only one shell that I would consider to be “successful” has been made in ICE (BOSshell, Xenon is too unstable), and that was done with ASM snippets. The more stable (than all the ICE shells, including BOSshell) shells were made in either C+ASM (VYSION) or ASM (Cesium, PHASM, Doors CE).
Past projects: HailStorm CE | Contagion CE | HUE CE | VYSION CE || Current projects: VYSION 2 CE | Crossroads CE
randomguy wrote:
okay, I guess I will just finish learning C and make one in C
You can’t make one in just C, you need ASM as well. Preferably, it would be made in pure ASM. Also, I would not recommend making a shell as a beginning project in C or any other language that you’re not completely comfortable in, as it’s probably the most difficult type of program to make. A search on Cemetech for “shell CE” or similar will show you this: lots of failed shells that were taken on by inexperienced programmers who underestimated the difficulty of their projects, and eventually had them fail due to bugs or the realization that the project was unrealistic.
I’m not telling you this to be mean, definitely go for it if you think you’re ready, but I don’t want you to be discouraged, as it seems to me that this is unrealistic.
Shells can only be made in assembly. You might be able to get away with doing the graphical stuff in another language, but at the end of the day all the necessary code to make a proper shell has to be done in assembly.
randomguy wrote:
Since I am new at C, do you have any suggestions for programs for me to make?
No. Use your own ingenuity.
Just make some kind of a very simple game to start out with, and focus on using good programming practices when making it. A utility program would be fine as well.
For Practice fell free to watch some of The coding train videos, He programs in JS but try your best to grasp what he's talking about.
